Spark plug tire inflator
Topic author - Posts: 314
- Last Name: Dufault
- MTFCA Number: 303
Tire inflator using engine compression...$50.00 plus shipping..
https://post.craigslist.org/manage/6857 ... go=display
addufo(at)gmail.com
addufo(at)gmail.com
- MTFCA Number: 303
Re: Spark plug tire inflator
How about I pay shipping to the contiguous 48?
$50.00 and I will mail it to you.
(Sure would like to offer it world-wide, but I am skeptical of the shipping charges, so can't do that...sorry. Dave)
- Last Name: Grisbee
- * REQUIRED* Type and Year of Model Ts owned: 0
Dave,
As you probably know,your inflator is adaptable to Model T by brazing a 1/4" black coupling to the bottom part of a T plug with good threads,then just screw in a hose adapter. Unhook the hose from the late plug unit and clamp it on the T one. Handy unit to carry on T tours. The down side,you're going to get a slight amount of gasoline inside your innertube.
- Last Name: Stroud
- Board Member Since: 2011
Steve, why would you get gasoline in the inner tube? Those use compression to run a pump that compresses clean outside air, at least the one that I have does. Dave
1925 mostly original coupe.
It's a sparkplug inflater. You take out a sparkplug,screw the adapter into the plug hole and air-fuel mixture under pressure from the compression stroke is not exploded in the cylinder but is forced through the hose into the tire.
- Last Name: Stroud
Steve, read the label on the box, "Pumps Only Clean Fresh Air" , no gasoline exhaust, gas or oil. It goes on to explain how it works. Bring the label in on close up and you can read it.
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
- MTFCA Number: 26459
- MTFCI Number: 20813
Hi, David. I will buy your tire inflator. PM sent. Bob
Darn modern contraptions,always have to read the fine print. In my day.....
- MTFCA Number: 303
Steve, there is a ball check valve in the device which permits only clean outside air to be pumped into the tire.
No air/gas mixture into the tire....as Dave S. said.
- Last Name: Hester
Hi, David. The PM wouldn't work for me but I got yours. Your check will be in the mail tomorrow (Monday). Thank you. Bob
