Still learning!
Kerry
Last Name: van Ekeren
Still learning!
Post by Kerry » Sun Jul 07, 2024 6:45 pm
Some years ago, a fellow club member had a T with a rebuilt differential that screamed like a fire truck siren. Well while flicking through some Canadian service bulletins, I learnt that in mid 1923 that Canadian T's had changed the diff gears, it seems that mixing with older ones was not a good idea, parts books also confirm the change. but I don't see them in the USA books. Did it happen to the US T's as well?
tdump
First Name: Mack
Last Name: Cole
Re: Still learning!
Post by tdump » Sun Jul 07, 2024 7:10 pm
if you notice yourself no longer learning, you are probably in a box.
we never stop learning.
Harvey Bergstrom
First Name: Harvey
Last Name: Bergstrom
Re: Still learning!
Post by Harvey Bergstrom » Mon Jul 08, 2024 8:27 am
It is never a good idea to mix and match ring and pinion gears. Always buy them as a set. When a differential is noisy, it is usually because of worn gears, however if it is a high pitched scream like a fire siren, the pinion gear is not shimmed correctly. When I had my differential apart and putting it back together, I took care to try different shims to get the gears to mesh properly. An old farmers trick is to take a strip of paper as wide as the gears and turn the gears drawing the paper through them. If the paper is all chewed up, the gears are too tight. If the paper comes through intact, the gears are meshed properly and will run just fine.
Kerry
Re: Still learning!
Post by Kerry » Mon Jul 08, 2024 5:40 pm
Good advice Harvey but not my point or question, mixing gears of different pitch is a no-no at any time, question is, did USA Ford use the change from 1923?
Re: Still learning!
Post by Wayne Sheldon » Mon Jul 08, 2024 9:28 pm
Quick answer, no.
I have read of the Canadian gear change, but never saw anything explaining the exact difference. It would also mean that mixing some Canadian gears with USA gears would likely be problematical.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: Still learning!
Post by rickd » Mon Jul 08, 2024 9:46 pm
Frank, did a quick check in the Encyclopedia documentation section, this might relate to the timing of a USA differential gear change: Jan 24, 1920 Acc. 575, Box 12- "Ten tooth pinion to be used with T-12B ring gear. T-12 48-tooth ring gear obsoleted. Old T-16, 12 tooth pinion, obsoleted."
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Re: Still learning!
Post by John E. Guitar » Mon Jul 08, 2024 11:01 pm
I wonder if the change was to the pressure angle, from 14.5° to 20°?
Re: Still learning!
Post by Original Smith » Tue Jul 09, 2024 10:42 am
I wonder why the picture above has the pinion facing the wrong way?
Re: Still learning!
Post by Jerry VanOoteghem » Tue Jul 09, 2024 10:54 am
I'd guess that it's because the identification dot, referred to in the text, is located there. What good would it do the depict it the "right way" and not show the dot?
