Identify that item!
Topic author - Posts: 761
- First Name: Thomas
- Last Name: Hicks
- MTFCA Number: 32518
Identify that item!
I plan to post pictures of things I can not identify on this thread, hopefully someone will know what they are.
If you have something unusual please do not hesitate to post a picture of it on this thread.
These look like a big pair of scissors, about 40" long:
- First Name: Rich
- Last Name: Bingham
Re: Identify that item!
Bend at the end of the handles suggests a blacksmith's tool. Can you post a closeup of the jaws, slightly open ? (Should be a fun thread Tom !)
"Get a horse !"
- First Name: Deke
- Last Name: Martin
They look like regular tin snips, but jeez, 40” long?!?
- Last Name: Hanlon
- MTFCA Number: 50191
I believe they are snips for glassmaking...
- Last Name: Hicks
They are rusted shut. I have added a penetrant and they should open eventually.
- Last Name: Hicks
Few more pictures:
- First Name: Rich
Thanks Tom. Mighty interesting. Glass blower's tool makes sense. Neat item !
"Get a horse !"
- First Name: Dennis
- Last Name: Seth
That tool looks like what our half blind cross eyed minister uses for circumcisions at the church. In more ways then one we have less men in church now.
- Last Name: Prince
- MTFCA Number: 22802
It is called bench shears and is a blacksmith tool, the long arm where it turns down goes into the hardy hole on the anvil and is for shearing sheet metal. They work pretty good altho most have a piece broken out of the cutting surface where someone has tried to cut round or square stock.
- Last Name: Hicks
Rusted metal...
- First Name: Herb
- Last Name: Iffrig
I believe the one above is what is left from a piece of harness that goes over the horse back.
- First Name: Rich
Herb nailed it. Missing one rein loop, it would have been sewn into the "saddle" and surcingle.
"Get a horse !"
Dennis
the one thing you never want to hear at that ceremony is: "it won't be long, now!"
NH Full Flow Float Valves
- Last Name: Hicks
iron
- Last Name: Hicks
Rusted and dirty...
- First Name: Herb
- Last Name: Iffrig
The item with the wood drill bit on the end is for drilling a bung hole in a wooden barrel. It makes a tapered hole that a tapered plug can be hammered into.
- Last Name: Hicks
Bifurcated!
- Last Name: Hicks
