Casting numbers on head
Franko
Topic author - Posts: 70
- Last Name: Franko
- * REQUIRED* Type and Year of Model Ts owned: 1914 & 1927
Do these numbers on my 1914 engine head indicate that it’s a 1926 head?
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
Re: Casting numbers on head
Those numbers are the month and the day the head was cast (May 26th).They are close to the date the block was cast (May 4th). . I hope this helps, Russ Furstnow
If you have a later high head you compare it with the head on your 14 and see if it’s the same height. That’s the easiest way to tell. Others that know if the casting number is for the later heads may can tell you the number information.
The water inlet appears to be a modified ? Model A part.
- Last Name: Tannehill
Measure from the bottom edge of the head to the top of a head bolt hole boss of the first hole on the right side. Should be a hair under 2 inches if it hasn’t been milled if it’s a low head.
Franko
- Last Name: Franko
Thank you everyone ! !
Chris Haynes
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
That is not the original engine number. You can see how low the number area is compared to the rest of the water inlet surface. The original number has been milled off and that number stamped in its place. Although this is common practice it is illegal.
That used to be legal to do, hence was commonly done. Exact rules varied by state.Chris Haynes wrote: ↑Wed Sep 25, 2024 6:13 pmThat is not the original engine number. You can see how low the number area is compared to the rest of the water inlet surface. The original number has been milled off and that number stamped in its place. Although this is common practice it is illegal.
Earlier low head styles of model T heads often had casting dates on them, but only the month and date, no year given. Several other details on the head may or may not help narrow down the year.
I don't even know if any high heads have a casting date at all? But I am fairly sure that most do not.
Kerry
- Last Name: van Ekeren
Some seem to have year as well.
