Motel t crank 26/27
Topic author - Posts: 17
- First Name: Patrick
- Last Name: Ainslie
Motel t crank 26/27
WTB good used 26/27 crank that is not more 10 thousand under and has been magnifluxed and would be satisfactory for use in an engine overhaul. Pat
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Motel t crank 26/27
FYI. A ‘26/‘27 crank with .003/.004 wear might clean up at -.010”. If it has .008 or more wear, it is likely to go -.020”. Most all of the ‘26/‘27’s wear off center on the rear main and grind more than double the wear measurement. Just something to be aware of in your search.
That is one of the reasons to start with a crank that isn’t already .020 or more to start with Thanks
