iPhone test
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
iPhone test
Test
- First Name: DEAN
- Last Name: YODER
Re: iPhone test
Ok I like it! THANKS
- Last Name: Hanlon
Re: iPhone test
Yeah everything is pretty easy from an iPhone...
Except avatars, I think the PC will be the way to go.
- First Name: Rod
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
- Board Member Since: 2014
Re: iPhone test
I noticed on the iPhone things look a little different. I dont see each persons profile on the right side of the screen.
- First Name: Gregory
- Last Name: Scholz
Re: iPhone test
On the iPhone, you are seeing the MOBILE feed.
Sometimes you can find a menu item in the app that will request the desktop version of a site. Sometimes it works, sometimes it does not.
Greg Scholz
4th Generation Caretaker
1914 Ford Touring
Survivor Class
http://personal.gregscholz.com/
Esko MN
KD0UYN ‘73
1914 Ford Touring
Survivor Class
Esko MN
KD0UYN ‘73
