FS: Imperial Manifold Primer
Post by TRDxB2 » Sun Apr 27, 2025 9:17 pm
The manifold is in excellent condition, the ports look unused. The plunger spring takes more effort than first expected but it needs to cause the short burst of fuel. The green tap is preventing a new ferrule from sliding off. Have everything else per the parts list except the supply elbow and 3/8 supply line. These parts, from the plunger to your fuel line, would need to be adapted to your carburetor feed setup anyway. T I will print off the instructions .
$120 plus shipping. Prefer PayPal to friend/family but will accept a personal check. If interested email me via the Forum
Re: FS: Imperial Manifold Primer
Post by TRDxB2 » Sun Apr 27, 2025 9:18 pm
Instructions..............
The diagram shows several check valves for siphon and squirt
Post by TRDxB2 » Tue Apr 29, 2025 9:46 pm
jump....jump.... bump....
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Wed Apr 30, 2025 9:06 am
Frank, shouldn't that be pump....pump....bump (the starter)?!?
Post by TRDxB2 » Fri May 23, 2025 12:59 am
pump..pump..pump.
