1927 Howe TT Fire Truck SOLD.
Bob in Texas
First Name: Bobby
Last Name: Wright
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout Fire Chief’s car,1924 Simms TT Fire Truck, 1927 Howe TT Fire Truck
Post by Bob in Texas » Mon Dec 01, 2025 8:41 pm
1927 Howe Fire Truck. TT Chassis. Runs, Drives, Stops as should. 3 cylinder positive displacement pump. No idea id pump works but externally everything operates as should. Discharge and suction valves need rebuilt. New front tires. New Kevlar transmission bands. Spot light and siren work. Hose reel in picture included but not mounted. NOT INCLUDED: Bell, Lanterns, tool box. Located near Houston, Texas $17,000
Bob on Upper Texas Gulf Coast.
"I was too young to know better.
Now I am too old to care."
Re: 1927 Howe TT Fire Truck
Post by TXGOAT2 » Tue Dec 02, 2025 11:42 am
Does this truck have have any kind of auxiliary transmission, or "high speed" axle gears?
Bob in Texas
First Name: Bobby
Last Name: Wright
Post by Bob in Texas » Tue Dec 02, 2025 3:46 pm
The rear axle is high speed rear end.
The transfer case has a low speed drive output with pu.p NOT in gear. Works like a Rux.
Post by TXGOAT2 » Tue Dec 02, 2025 5:33 pm
Big improvement... maybe 30 MPH?
Bob in Texas
First Name: Bobby
Last Name: Wright
Post by Bob in Texas » Wed Dec 03, 2025 7:09 am
I have never clocked it but I am sure yes.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Wed Dec 03, 2025 12:16 pm
According to Brent Burger in Spokane,
Burger in Spokane wrote:
Mon Jun 24, 2019 10:48 am
Putting Henry's comment into perspective, a 7:1 ratio gear set will have your engine
maxed at 20mph. Even slower if it is not rebuilt and balanced. A rebuilt and balanced
engine with a 5:1 gear set will do a comfortable 35 and have an upper end approaching
50...
He puts a lot of miles on his TT Flatbed in Eastern Washington. The Fire Truck is undoubtably heavier, but the flat ground cruising speed should be close.
Pat, you sound pretty interested, I think that you should buy this one. ;)
Keep crankin',
Eric
Post by TXGOAT2 » Wed Dec 03, 2025 2:01 pm
Send money..... !! (And indoor storage space!)
Bob in Texas
First Name: Bobby
Last Name: Wright
Post by Bob in Texas » Wed Dec 03, 2025 9:48 pm
Truck sold
