Roof overhead
Ralph F
Topic author - Posts: 170
- First Name: Ralph
- Last Name: Fitz-Gerald
Roof overhead
I need to find some valves for a Roof Liberty Overhead. The valve deminsion are the following
Head diameter-1.685”
Stem diameter- .308
Length- 5.839
My other question is what the valve grind? Is the grind similar to what you would grind on model t
Fitz
Stem diameter- .308
Length- 5.839
Fitz
frontyboy
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Re: Roof overhead
I have a Roof 8 valve and I can drop a valve and check the degree of the valve face and the degree of the seat. If that would help you. My head is just sitting on the shelf ready to install on my engine when I get to it. Do you have an exhaust manifold, I may not use mine haven't made up my mind yet.
just sayin
frontyboy.
just sayin
frontyboy.
AndreFordT
- First Name: Andre
- Last Name: Valkenaers
Re: Roof overhead
The 16 valves Roof I have here takes standard model T valves, just not 8 but 16.
I don't know for the 8 valves Roof.
Andre
Belgium
Andre
Belgium
Gary_in_MN
- First Name: Gary
- Last Name: Anderson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster/ Depaul OHV
tman1913
- First Name: Mike
- Last Name: Bender
- * REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Re: Roof overhead
SBI has PDF,s you can download. You have some dimensions and should find something that will work. Nothing special about a valve angle grind.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Roof overhead
Biggest issue will be finding an off the shelf exhaust valve with a stem that long. Many engines like small block Chevrolet have valve stems just over 5" long.
Chevrolet 216 qnd 235 ci engines had a long stem that can be cut down if the head diameters are close. Also at one time Egge Machine had valve blanks available. Shortening valve stems and turning down valve heads is something that you may have to do if you find a valve to modify.
Kevin Pharis
- Last Name: Pharis
Re: Roof overhead
Manley Valve has a custom order option. Won’t be cheap, but they’ll be right
Re: Roof overhead
If you can get ahold of an automotive engine valve catalog you could spend some time looking for something that matches. You could go with a larger diameter head and have it cut down along with longer stem.
