FS Anco Timer
Topic author - Posts: 1015
- Last Name: Stroud
- Board Member Since: 2011
FS Anco Timer
FS Anco timer. The inside is in very nice shape, no rust with very little wear on the contacts. Outside, not so much. Has a lot of minor rust with a couple of small pits. The contact screw nuts are a bit rough, probably need to be replaced. One of the screws has been cut off and is too short. It has three of the original brass wire ends on the contacts. It will work nicely with a bit of work, just won't look all that great. Would be nice for a driver, survivor, doodlebug, etc. $10.00 plus shipping. Dave
1925 mostly original coupe.
- Last Name: Stroud
Re: FS Anco Timer
$7.50 plus shipping. With a little work, it would make a nice spare to throw in your toolbox. This is the Anderson style timer, very good timers. As I said, I can text pictures. Thanks, Dave
