What the — ? A commutator question
hull 433
Topic author - Posts: 244
- First Name: Stan
- Last Name: Gadson
My commutator was acting up, so I took it apart and found the fiber washers had split.
In the process I noticed a notch in the brass spacer nuts. Not in the Ford parts list for the year of my car so I’m wondering what they’re for and whether they’re Ford parts at all — or just repurposed from something else during an ancient shop repair.
Re: What the — ? A commutator question
A picture of your commutator would help. There were many styles and I'm just using one as example. Is it like yours?
In comparing to the timer on the left, your timer would need a nut or equivalent to hold the threaded piece in place when the thumb nut was loosened or tightened . So is the mystery piece threaded?
hull 433
- First Name: Stan
- Last Name: Gadson
Hey Frank,
Here’s the mystery commutator in situ, with a well worn stock example on the right for comparison. Both came with the car. The contact points on both have a smaller surface area than your example.
My initial reaction from the photo is that the disk may have been added to raise the wire contacts away from the timer housing because of the amount of solder on the connectors. Wonder what brand that timer is.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
I am not an expert on the early cast timer but my gut is telling me it is one of the many replacement ones made over the years.
The Encyclopedia has some good pictures of the Oil Funnel 1912 cast style and I assume it is built like that one but without the funnel
Look at how the insulators, nuts, and other hardware is done for the terminals.
If it were mine I would make new insulators to replace them and add new brass nuts to replace what I assume is their attempt to be a nut.
It might need a quick trim on the inside but does not appear to have much wear.
Mike
Mike
hull 433
- First Name: Stan
- Last Name: Gadson
Here is the accessory timer case on the left, compared to a stock (but well worn) Ford timer on the right. The missing parts were on another table when I took the picture.
The accessory timer seems to use wood for its insulation, and all four of the wood grommets have split. I won’t say it’s a cheap construction for failing after 110 years, but the Ford insulators in comparison are in excellent shape. If it were not for the heavy grooved wear I’d be using it.
The car came to a sudden halt while driving, allowing me to coast to the curb. Attempts to restart it did nothing save one threat of a kickback. Normally she stars and runs nicely, so I’m thinking the split insulators led to a short. Has anyone experience with this?
Mike Silbert
- First Name: Mike
Stan,
If a timer terminal (or wire) shorts it will cause that coil to continuously fire the spark plug.
This will effectively kill that cylinder and possibly fire back through the carburetor due to sparking when the intake valve is open.
The clue is listening to the sound the coil box makes.
While cranking it normally will have spots that coils fire and spots where coils do not. Also each coil sounds slightly different so that may be noticed also.
But the key is noticing that the coil box sounds different from normal when it happens.
Coming to a sudden halt when driving is interesting.
To shut off a running engine it normally takes killing more than one cylinder.
At shows I start removing coils until there is only one left and the engine still runs, just a bit rough.
I would expect an insulation failure would produce a rough running car and not a sudden shut off, so this might not be the bottom of the issue.
I have seen timer and wiring shorts before but never on more than one cylinder at a time.
I have seen a bunch of random insulators crack but I cant recall if any of them were ever on a timer.
When I find cracked insulators I just make new ones to fit.
My opinion is: The timer needs to be fixed, but that might not the end of your troubles.
I hope you prove me wrong and it runs great soon so you can go back to enjoying it.
Mike
Mike
Mike has a point.
Your engine kill doesn't sound like a timer issue.
Sounds like a power in put issue. Faulty switch, band fuzz interfering with the mag contact, etc.
Mark Nunn
- Last Name: Nunn
I had that happen to me. It was my ignition switch.
