I removed the differential which was pretty straight forward. I'm ready to reinstall the unit and am wondering if there is something I should be aware of so I don't mess it up. I'm going to grease the universal joint heavily before installing.
Thanks for the help.
Larry
Kennebunk, Maine
Rear End Install
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
Re: Rear End Install
If you pack the ball with stiff grease around the U-joint it’s easier to align with the trans. tail shaft, but it’s still best to have help as you move the axle/driveshaft assembly into position.
Get a horse !
As stated above you'll need help because the end of the u-joint has a mind of its own when aligning with the transmission ball cap fourth main. While not necessary they do make a tool to support.. DIY? .
- Attachments
- ujoint tool.png (39.5 KiB) Viewed 87 times
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Read these threads in order to avoid pinching or cutting your fingers on the driveshaft ball while installing universal joint shaft into the "fourth main" of the engine.
https://www.mtfca.com/discus/messages/1 ... 1300480114
https://www.mtfca.com/discus/messages/1 ... 1292108551
Since my contribution to the 2011 thread, I have acquired universal joint alignment Z tool at a swap meet, which is basically a thin, open end wrench with a long handle (Dan Hatch posted a photo of one in the second link I posted above).
Make sure the square head on the spring centre bolt is located in the square hole in the rear cross member on the frame, if indeed you took the spring out with the rear end.
Alan from down under.
Rich P. Bingham
- First Name: Rich
Tool ?? $24.95 ?? Mr. Cheapskate fashioned one from a coat-hanger.
Get a horse !
