WARFORD GEAR BOXES
Topic author - Posts: 329
- First Name: Herbert
- Last Name: Chaffin
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1911 touring, 1913 roadster, 1914 touring
- MTFCA Number: 227
WARFORD GEAR BOXES
Have 2 Cast Iron Warford Gear Boxes, no cracks or damage, $100.00 ea plus shipping
- First Name: Forest
- Last Name: Ledbetter
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Holmes tow truck
- Board Member Since: 2014
Re: WARFORD GEAR BOXES
Just the cases, or do they have the gears?
- Last Name: Nielsen
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1924 Speedster
- MTFCA Number: 49701
I have a complete cast iron Warford gearbox, gears look good, shifts fine and has the adapter on the front for the other U-Joint.
I'd like to sell it, $300 plus freight
Mark
Mark
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
- MTFCA Number: 25458
Mark what do you think it would cost to ship to 01832? I also have a Fastenal a few towns over also thanks ken
- MTFCA Number: 227
UPS to 01832 would be $41.75
Sounds good mark send me an address for the check thanks Ken
- MTFCA Number: 227
KEN 1939N S. MAIN ST CORONA CA 92882 $141.75 GLEN (MARKS DAD)
- MTFCA Number: 227
1939 S. MAIN ST. NO N
I was interested in the complete unit for $300 that mark was selling ,maybe a mix up ?
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
- MTFCA Number: 26459
- MTFCI Number: 20813
Feller probably shouldn't jump into the middle of one guy's ad and start selling his own stuff. Just saying...
- MTFCA Number: 227
$300.00 IS A GOOD PRICE IF THEY HAVE GEARS. I SOLD 2 GOOD ONES FOR $450.00. BUT IF THE GEARS ARE NOT GOOD FORGET IT. GLEN
Bob Hester is absolutely right!
BAD FORM TO ADVERTISE ON SOMEONE ELSE'S F/S AD !!!!! Any way I can make myself clearer???
This is Chaffin's ad...no one else's
NH Full Flow Float Valves
- First Name: Thomas
- Last Name: Butterworth
- * REQUIRED* Type and Year of Model Ts owned: 1911 speedster
Mark not good of you to jump on someone's ad .
Sorry for the confusion Glen,when I saw mark I assumed it was your son where as it was on the same add. Ken
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
OK I think there is still room for confusion. No one has been able to tell me if you can put the gears from a aluminum case warford into a cast iron case to bolt it direct to the back of the T trans like the aluminum case . If this is possibility I would be interested especially if some one would pick it up & bring it to the San Diego speedster run for a $20 dollar bill (just trying to save a bit )
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Some gears with fit depending on year of manufacture but the majority will not. The idler shaft down low is larger on the cast iron (truck) models, the gears are in some are of different tooth count, and etc.
Hope this Helps,
Hank in Tin-A-See
Hope this Helps,
Hank in Tin-A-See
- First Name: craig
- Last Name: leach
Thanks Hank,
