Duplex spare tire carrier
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
for sale … Duplex double spare tire carrier … good condition … will need key made and mounting bracket … price is $100.00 plus postage … will need to know your zip code for postage rate … always an optimist Gene French ph. 970-581-2808 ...address 49519 cr.23 Nunn, Co. 80648
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: Duplex spare tire carrier
How does it attach to the car?
- First Name: Layden
- Last Name: Butler
It does not attach to the car. It clamps the second spare to your existing spare which is held to the car by your existing carrier.
- First Name: Gene
- Last Name: French
Layden:
thanks for the info. … I have never used a unit like this … my Dodge Brothers touring has a 3 point mount for the spare … can see how this would work though by clamping to the first rim in the oem mount … always an optimist...gene french
And to my chagrine I have found these to be mostly for 21" split rim wheels and not for 30 x 3 1/2 demountables. You might wish to check and see.
NH Full Flow Float Valves
- First Name: Gene
- Last Name: French
Scott:
I don't have any 21" split rims … I did compare it to a 21" wire wheel and it would be within the range of the adjustment to clamp onto a 21" rim … have had this unit for probably 25 years … got it with a large group of parts in a bulk purchase … I am clearing out some of this bulk … I have WAY too much STUFF ! always an optimist ...Gene French
