1923 / 24 Model T Tudor $7,100 OBO
Budreau
First Name: Chad
Last Name: Budreau
* REQUIRED* Type and Year of Model Ts owned: 1923 Tudor, 1915 Speedster, 1924 Depot Hack, 1925 Touring
MTFCA Number: 377
Post by Budreau » Tue Aug 13, 2019 5:14 pm
This Model T has been a great car for over ten years, but we're running out of space. I own four Model Ts and need some room. Accepting offers.
Here are the good, bad, and ugly.
Engine rebuilt 9 years ago. Generally all stock. Engine was overbored with 0.030 aluminum pistons (vs cast). Runs well.
Even compression around 55 pounds.
Rear end rebuilt about 7 years ago.
Lots of original items. Appears to be original fabric under some of the seat covers. I also have some side panels that appear to be original. Floor boards appear to be original solid wood. I have the back window curtain rod (not installed).
Passenger seat reclines too much and needs repaired. I'm including a spare passenger seat if you'd rather replace or resell.
Generator recently stopped working. May need a new cutout.
Radiator is flat tube (good for daily driving) and is only 5 years old.
Back windows have hand cranks (yet to be installed).
Spokes are good and solid.
This is a 20s car. It looks good at 20 feet away or at 20mph. Could use a decent paint job.
Has a hole for a speedometer on the dash which is currently covered by the MTFCA decal.
Titled in Indiana as a 1923, but is likely a 1924. I suspect this was one of the first Tudors off the assembly line in 1923 and therefore was tiled at the year of purchase.
[b][size=130]Chad Budreau[/size][/b]
1924 Depot Hack | 1925 Touring
Budreau
First Name: Chad
Last Name: Budreau
MTFCA Number: 377
Re: 1923 / 24 Model T Tudor $7,100 OBO
Post by Budreau » Tue Aug 13, 2019 5:32 pm
Budreau
First Name: Chad
Last Name: Budreau
MTFCA Number: 377
Re: 1923 / 24 Model T Tudor $6,900 OBO
Post by Budreau » Wed Aug 21, 2019 10:08 pm
Budreau
First Name: Chad
Last Name: Budreau
MTFCA Number: 377
Re: 1923 / 24 Model T Tudor $6,600 OBO
Post by Budreau » Thu Aug 22, 2019 9:13 pm
Let's try $6,600
cve92
First Name: Carl
Last Name: Finchum
* REQUIRED* Type and Year of Model Ts owned: 1919 touring
MTFCA Number: 49474
Post by cve92 » Sun Aug 25, 2019 9:36 pm
Would like to ask you where are you located? Is it in Indiana?
Charles J
First Name: Charles
Last Name: Jenkins
* REQUIRED* Type and Year of Model Ts owned: Coupe
MTFCA Number: 28066
Post by Charles J » Mon Aug 26, 2019 1:27 pm
Engine no should tell you what year it is also what happened to the outside sun visor
Budreau
First Name: Chad
Last Name: Budreau
MTFCA Number: 377
Post by Budreau » Mon Aug 26, 2019 5:52 pm
The T has been sold. Thanks MTFCA.
