wanted right hand parts
Topic author - Posts: 22
- First Name: andrew
- Last Name: o sullivan
- Board Member Since: 2014
Wanted Right Hand parts.. looking for hogs head, steering bracket, front axel steering rod , and brake lever , i'm heading to Hershey this year . email me on aosconstruction@gmail.com
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: wanted right hand parts
I never thought of the brake lever, I think you could reverse it all to make it work, except for the cam it would need turned and welded back on.
- First Name: Joe
- Last Name: Bell
Mike Lepsac has some parts he is hauling to hershey.
- First Name: Brad
- Last Name: Kirtner
- MTFCA Number: 50618
I’ve got a nonstarter hogshead with pedals in va. Won’t be going to Hershey though.
Brad
Brad
- Last Name: Williamson
iron or aluminum?
- First Name: Brad
Iron. Good shape. Will need cams. Tuckett brothers in the UK has them for a decent price. Some can be interchanged with the RHD units.
- First Name: Brad
Light surface rust on the inside. Easily cleaned. The outside has a good protective coat of paint. The pedal shafts are in good shape from what I can tell. Better than what I had to start with in my car.
$100 plus the ride and it’s yours.
Brad
Brad
I'll buy them
Richard Williamson
Richard Williamson
the lever can't be turned ,you would be better to look for the right hand side one? you can turn it but it would be a lot of work and it would be in the way of the leg room you'd need to bend the other way . joe send me on Mikes lot number ill call there Tuesday
