wanted right hand parts
andrew o sullivan
First Name: andrew
Last Name: o sullivan
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1910 touring 1914 pickup
Board Member Since: 2014
Post by andrew o sullivan » Fri Sep 27, 2019 5:19 pm
Wanted Right Hand parts.. looking for hogs head, steering bracket, front axel steering rod , and brake lever , i'm heading to Hershey this year . email me on aosconstruction@gmail.com
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Re: wanted right hand parts
Post by Joe Bell » Fri Sep 27, 2019 7:41 pm
I never thought of the brake lever, I think you could reverse it all to make it work, except for the cam it would need turned and welded back on.
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Fri Sep 27, 2019 7:42 pm
Mike Lepsac has some parts he is hauling to hershey.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
MTFCA Number: 50618
Post by Jeepbone1 » Fri Sep 27, 2019 9:11 pm
I’ve got a nonstarter hogshead with pedals in va. Won’t be going to Hershey though.
Brad
RichardW
Last Name: Williamson
* REQUIRED* Type and Year of Model Ts owned: 1913
Post by RichardW » Fri Sep 27, 2019 9:15 pm
iron or aluminum?
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Post by Jeepbone1 » Sat Sep 28, 2019 12:38 am
Iron. Good shape. Will need cams. Tuckett brothers in the UK has them for a decent price. Some can be interchanged with the RHD units.
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Post by Jeepbone1 » Sat Sep 28, 2019 12:45 am
Light surface rust on the inside. Easily cleaned. The outside has a good protective coat of paint. The pedal shafts are in good shape from what I can tell. Better than what I had to start with in my car.
$100 plus the ride and it’s yours.
Brad
RichardW
Post by RichardW » Sat Sep 28, 2019 1:20 am
I'll buy them
Richard Williamson
andrew o sullivan
First Name: andrew
Post by andrew o sullivan » Sat Sep 28, 2019 12:07 pm
the lever can't be turned ,you would be better to look for the right hand side one? you can turn it but it would be a lot of work and it would be in the way of the leg room you'd need to bend the other way . joe send me on Mikes lot number ill call there Tuesday
