For Sale: New Copper Manilfold Rings
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Thu Oct 24, 2019 5:19 pm
Here's 2 sets of 6 new heavy copper manifold rings imported from N.Z., I believe - both sets $50.00 mailed in the U.S. Drop me a note through here, please.
Bill Crosby
First Name: Bill
Last Name: Crosby
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Re: For Sale: New Copper Manilfold Rings
Post by Bill Crosby » Thu Oct 24, 2019 5:35 pm
Steve, Email Sent.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Thu Oct 24, 2019 5:47 pm
Rings are spoken for - thanks MTFCA !
art32mor
First Name: Art
Last Name: Morra
* REQUIRED* Type and Year of Model Ts owned: 24T Touring
MTFCI Number: 14286
Post by art32mor » Thu Oct 24, 2019 8:05 pm
I have used these work great
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Thu Oct 24, 2019 9:27 pm
Steve, I tried to get ahold of the company in New Zealand a year back but I was told they were out of business. Plus they were more expensive than what you sold them for. I had a set some years back and I thought they were better than anything else on the market, but, you had to have a straight exhaust manifold. Frank.
art32mor
First Name: Art
Last Name: Morra
MTFCI Number: 14286
Post by art32mor » Thu Oct 24, 2019 11:30 pm
Bought a set via Ebay $16+ postwitch ran it up 20+ for 6
Same guy buying honey comb cores
Post by Allan » Fri Oct 25, 2019 11:19 pm
They are Australian made and available from Fuel Tank and Radiator Services. You will be pleasantly surprised by the price, especially if you order a few sets for the one parcel.
When re-fitting Henrietta's original manifold after our national Tour, I found it to be bent almost 1/8". These rings are made of thick copper and can take some tweaking. By reshaping the two end rings a little, and filing a taper on the end which goes to go to the block, I was able to fit the bent manifold quite satisfactorily.
They will even take filing to fit in the undersized ports in new reproduction manifolds.
Hope this helps,
Post by TRDxB2 » Sat Oct 26, 2019 1:51 am
MAC's Auto shows similar manifold rings under two different part numbers
https://www.macsautoparts.com/ford_mode ... -duty.html
https://www.macsautoparts.com/ford_mode ... ieces.html
They also have regular ones and have them listed for sale individually under 3 different part numbers
https://www.macsautoparts.com/ford_mode ... er&x=0&y=0
Looks like Snyder's has something similar
https://www.snydersantiqueauto.com/Prod ... hByKeyword
Post by Allan » Sat Oct 26, 2019 9:22 pm
Just Google Fuel Tank and radiator Services and you will find them under parts/tools. The price will surprise you.
william
First Name: William
Last Name: Rathert
* REQUIRED* Type and Year of Model Ts owned: 1909, 1915, 1917, 1926
Post by william » Sat Oct 26, 2019 10:02 pm
If anyones going to order any, I'd like to buy a couple sets and maybe if enough people buy, a volume price can get obtained. Thanks
Post by TRDxB2 » Sat Oct 26, 2019 11:04 pm
Not sure why you wouldn't buy these from Snyder's or MAC's see links above
I priced a set of six from FTRS in Australia. $21.50 AUD converting to USD is $14.67 with shipping at $26.22 AUD so $47.22 AUD to USD = $32.20. Not sure if tariff / duties apply (away around this is to have them shipped as a gift when possible)
Snyder's price is $27.50 and MAC's $32.99 assuming they have them in stock. I had ordered something from Australia last year estimated shipping time was 11 to 35 days, took 20 days.
Post by TRDxB2 » Sat Oct 26, 2019 11:07 pm
Mac's Item
It's Bill
First Name: Bill
Last Name: Hoffer
MTFCA Number: 32571
MTFCI Number: 24364
Post by It's Bill » Sun Oct 27, 2019 7:19 am
I sent my engine out for rebuild, and so had to remove the manifolds. Had copper rings from Langston installed. Can they be reused and still provide a good seal?
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Oct 27, 2019 11:42 am
This is the "classified" section Fellas - post in the Forum if you feel the need to comment regarding a subject !
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sun Oct 27, 2019 1:58 pm
Bill..yes you can re-use them if they're not messed up.
