Keep on trucking
- First Name: Ken
- Last Name: Lefeber
Re: Keep on trucking
What's on the tires on the 2nd picture from the top?
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Those are air cushioned solid rubber tires. The air cushion comes from the holes in the tires you see in the picture as black dots. No flat tires to fix was the marking they were sold by.
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
The Holmes Bread truck in the third picture may not be a Ford. Both the front and the rear axles are on two springs, all of the others are on the expected Ford single transverse spring, at least in front.
Eric
Eric
- Last Name: van Ekeren
It looks T to me, just a spring kit of some sort fitted.
