RHD hogs head purchase
Tmodelt
First Name: Kim
Last Name: Wynn
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Post by Tmodelt » Tue Dec 17, 2019 9:14 am
I would like to thank Mr. Joe Bell for allowing me to purchase a RHD hogshead that he had.
I am attempting to build a somewhat unique 2 person boattailed roadster/speedster (RHD, suicide doors, removable hardtop & some other modern amenities).
I am presently assembling the drive train.
Engine in progress
Engine in progress
Intake manifold and carbs
Tmodelt
First Name: Kim
Last Name: Wynn
Re: RHD hogs head purchase
Post by Tmodelt » Tue Dec 17, 2019 9:15 am
The new RHD hogs head to be installed this week. Not pictured yet
Kerry
Last Name: van Ekeren
Post by Kerry » Tue Dec 17, 2019 4:01 pm
If you are running removable ear bands, don't forget to flip them around as well.
Tmodelt
First Name: Kim
Last Name: Wynn
Post by Tmodelt » Tue Dec 17, 2019 4:16 pm
The removable portion would then go opposite the pedals so that the rotation of the transmission drums would keep them seated. Correct?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Dec 17, 2019 4:40 pm
Kim,
Is your new name, "Yell'r Dawg"?
Love You to Man!
Kerry
Post by Kerry » Tue Dec 17, 2019 4:49 pm
No, like a LHD they are on the pedal side so on a RHD they are on the pedal side.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Dec 17, 2019 5:10 pm
I assume you have the starter version? In Canada all I have are the pre starter versions (2 aluminum, 1 cast iron). I am thinking of doing a “surgery and weld job” and add a starter to the cast iron one.
My 13 touring is RHD and has been on the road for 19 years
Tmodelt
First Name: Kim
Last Name: Wynn
Post by Tmodelt » Tue Dec 17, 2019 7:42 pm
Kerry, wouldn't the direction of rotation attempt to lift the band pins/tabs off the end pieces? Just clarifying as I have absolutely NO experience with RHD.
Les, I have one with a starter mount even though I will be blocking off and use a removable starting system similar to what is used in Formula 1 and INDY racing. Building as a multiple purpose (daily driver and racing).
Hank, Good name. I hadn't thought much about naming yet. I was leaning toward "The Wynco Special" developed by Wynco Enterprises, designed by the Department of SWAG (Stupid Wild Ass Guesses) HA!
Chassis has 21" Model A wheels, aluminum Watford 3 speed aux trans, Ruxtell 2 speed diff and has been lowered approximately 7" ( how low can you go), fiberglass roadsters tub so that when I cut for suicide doors, I will not destroying an original steel body. A lot of ambition, but it keeps me out of bars and from chasing wild women!
Kerry
Post by Kerry » Tue Dec 17, 2019 9:55 pm
Kim.
If rotation was a problem then LHD T's would have the same issue when using the brake band when going in reverse.
I've never seen any problems as long as the band end is locked correctly on the ear.
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Wed Dec 18, 2019 1:44 am
A little thread drift, but I have pulled worn out bands with removable ears on the "wrong" side. Good luck with the project and I look forward to photos.
Andy
Tmodelt
First Name: Kim
Last Name: Wynn
Post by Tmodelt » Wed Dec 18, 2019 9:25 am
I plan on painting the "new" hogs head today and installing when dry. Using a "rattle" can off the shelf color. I will then install the front plate distributor and oil pump. I have a pump like in Hank's photos.
I hope my kids take pity on my wife and supply me with more engine speed parts for Christmas. I fought it though as they didn't ask me what I still wanted/ needed. HA!
