not model T Continental engine
Martin
First Name: Martin
Last Name: Cobb
* REQUIRED* Type and Year of Model Ts owned: 1917 engine, 1916 Runabout, 1915 engine & chassis
MTFCA Number: 31441
Post by Martin » Tue Dec 10, 2019 9:34 am
I'm working on a late 1920's "Reiland and Bree" truck with a Continental OHV six engine that is missing its intake manifold. Any ideas where I can find one?
John M Maslack
Last Name: Maslack
Re: not model T Continental engine
Post by John M Maslack » Tue Dec 10, 2019 10:15 am
Continental made mostly industrial engines, so perhaps you could find something from the industrial engine parts houses. I used Foley Industrial Engine years ago for a camshaft. It was expensive but beggars can't be choosers...I think they are still in business....
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Dec 10, 2019 10:21 am
Continental made engines for a number of different makes of cars. I believe a Jordan is one of them.
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Tue Dec 10, 2019 11:07 am
They made engines for cars, trucks, airplanes, industrial, farm machinery, and army tanks.
MTFCA Number: 1219
Post by Rich Eagle » Tue Dec 10, 2019 11:35 am
This Hemmings article lists many vehicles that used continental engines:
https://www.hemmings.com/blog/2008/12/1 ... lete-list/
I have a red seal 20s flat head that was on a saw.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Dec 10, 2019 11:38 am
We’re also used in the marine industry all the way up into the early 1960’s. The parts did not change much at all if any.
Hope this Helps
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Tue Dec 10, 2019 12:14 pm
Some older farm tractors had Continental engines in them also.
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Tue Dec 10, 2019 1:16 pm
They're still alive as Continental Aerospace Technologies, a *lot* of private aircraft run Continental engines... Also, they still make both air-cooled (inder the "Wisconsin" brand) and liquid cooled industrial motors. Back then they built engines for a bunch of different makes...
May not help a *lot* but you might be able to start chasing it down...
http://www.pittauto.com/default.aspx?pa ... aMQAvD_BwE
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Tue Dec 10, 2019 4:03 pm
My Globe Safety Scooter had a Continental Red Seal engine in it.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
MTFCA Number: 29135
Post by BobShirleyAtlantaTx » Fri Dec 13, 2019 7:42 pm
In my youth I had a Marion Handley rolling chaise that had Continental Red Seal. Placing a cup of water on the running engine, it barely made ripples.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Tue Dec 17, 2019 7:37 pm
Try the multi-cylinder forum after clicking on the XenForo Antique Engine Forums over at smokstak.com if you don't find one. Someone might be able to help over there.
Ooh, looks like a Purolater full flow oil filter on that engine. :twisted: What year is that image from Martin? :)
MS&M's Twin City tractors implemented the full flow Purolater in the late 20's and always looking for more filter info.
Martin
First Name: Martin
Last Name: Cobb
MTFCA Number: 31441
Post by Martin » Wed Dec 18, 2019 2:53 pm
Not sure of the year of the image, it was in a brochure advertised on e-bay but someone beat me to it. Continental R-series engines were introduced in 1928, that may be the date of the brochure. Thanks for mentioning smokestack.com I'll try it.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Fri Dec 20, 2019 1:03 am
Thank you sir. :)
Martin, would you help me some more?
Are the Continental engines outfitted with Purolater filter assemblies that look like this?
If Purolaters: Are your oil filters round cast bases or flat sided bases? :)
I know, I know: Who the heXX is wanting info about that trivial matter?
Oh! Do you have any evidence of a Purolater transfer/decal on that oil filter can (canister)?
Means the world to me for the early production Twin City tractor engine I'm working on. :)
Thank you.
D
Martin
First Name: Martin
Last Name: Cobb
MTFCA Number: 31441
Post by Martin » Sun Dec 22, 2019 11:39 am
[image][/image]Duey
The Continental brochure shows the same filter you posted, but the engine I'm working on has a different style. I will look more closely to see if there's a label on the filter next time I'm working on it.
Martin
Brochure.docx
(205.3 KiB) Downloaded 141 times
Martin
First Name: Martin
Last Name: Cobb
MTFCA Number: 31441
Post by Martin » Fri Jan 03, 2020 4:10 pm
Duey,
Sorry, but the decal on the oil filter is completely illegible.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sat Jan 04, 2020 11:29 am
Thanks Martin! That's OK.
Very interesting filter. :)
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post by thom » Fri Jan 31, 2020 10:03 pm
My '52 Massey Harris Pony tractor uses a Continental 4 cyl engine.
