WHEEL BERG PACKER,
RichardG
Last Name: Grzegorowicz
* REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
WHEEL BERG PACKER,
Post by RichardG » Fri Jan 24, 2020 1:14 pm
I KNEW I HAD THIS ITEM , ITS USE FULL WHEN PACKING GREASE IN A WHEEL BERG, YOU STILL GET THE HAND GREASY BUT THE BERG'S GET FILLED
https://www.mtfca.com/phpBB3/download/file.php?mode=view&id=41940
https://www.mtfca.com/phpBB3/download/file.php?mode=view&id=41939
https://www.mtfca.com/phpBB3/download/file.php?mode=view&id=41938
IT WILL PACK A GOOD SIZE BERG. BY PLACING THE WIDE SIDE OF BERG ON BOTTOM OF PACKER AND THREADING TOP HALF DOWN TIGHT MOUNT THE GREASE GUN TO THE FITTING AND PUMP , TO TELL WHEN BERG IS FULL OPEN COVER TO CHECK .IF NOT RE TIGHTEN COVER AND GIVE IT ANOTHER SHOT TILL IT IS, $20 PLUS POST ITS MADE SO YOU CAN REMOVE THE FITTING AND THRED THE GREASE GUN HOSE INTO TOP FITTING FOR A PERMANENT FIXTURE.
kirbypray
First Name: Kirby
Last Name: Pray
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring
Re: WHEEL BERG PACKER,
Post by kirbypray » Fri Jan 24, 2020 4:47 pm
I’ll take it! I’ll pm you.
RichardG
Post by RichardG » Sat Jan 25, 2020 9:23 pm
PACKER IS SOLD
Jeff Hood
First Name: Jeff
Last Name: Hood
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
MTFCA Number: 25636
Post by Jeff Hood » Sat Jan 25, 2020 11:11 pm
Both cones should be oriented in the same direction. The bearing gets greased and you can see that the grease has gone all the way through. You don't have to take it apart to see the bearing. Also uses less grease.
RichardG
Post by RichardG » Wed Jan 29, 2020 8:26 pm
THANK YOU JEFF, I RELAY'D INFO TO KIRBY.
