What is this part?
Topic author - Posts: 79
- First Name: Michael
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster 1914 Speedster 1925 Touring 1926 roadster pickup
- MTFCA Number: 22510
- First Name: Alex
- Last Name: Falconer
- * REQUIRED* Type and Year of Model Ts owned: July 1926 Canadian Touring
Re: What is this part?
A fan belt guide?
I thought what I'd do was, I'd pretend I was one of those deaf-mutes...
- MTFCA Number: 52564
Looks like a fan belt guide that mounts to timing gear cover. If I had my copy of their catalog here I would look it up.
1920 Dodge touring
1920 Dodge touring
Thanks. Makes sense now.
- First Name: Philip
- Last Name: Lawrence
- MTFCA Number: 5591
- MTFCI Number: 25062
- Board Member Since: 2014
A worthless accessory if your crankshaft and fan pulleys have the correct crown. Much better to fix or replace the pulleys. Would you put a bandaid on your arm if it was broken?
- MTFCA Number: 1219
Definitely "A worthless accessory if your crankshaft and fan pulleys have the correct crown". However I have them on 5 of my T's. 3 are homemade. Most ones are this variety that Jay shared with us years ago. I plan to improve my pulleys as time permits.
http://www.mtfca.com/discus/messages/179374/185131.html
