FS Z TOOLS
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 12:09 pm
I have the following Z tools available for purchase. Quantities available are as depicted in each photo. As well as the price. Shipping for a single item is $8.30 USPO Small Flat Rate Priority envelope. If you purchase two or more, the shipping will be $15.05 USPO Medium Flat Rate Priority. Purchase several items at a time and save on shipping. First come first serve. Get them while supplies last. Payment by PayPal (Preferred) or check. PM me or call Mark Chaffin (951) 805-0928
Connecting rod clamp bolt wrench 3-Z-647 / 5-Z-209 $25.00 each
Flywheel cap screw wrench 3-Z-1179 / 5-Z-210 $30.00 each
1/2" L socket wrench 5-Z-155 $25.00 each
Main bearing bolt wrench 5-Z-156 $25.00 each
Main bearing bolt nut wrench 5-Z-156 $25.00 each
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 12:13 pm
Front axle spindle bearing cone wrench 3-Z-699 $35.00 each
Universal joint to transmission tail shaft wrench 5-Z-196 $35.00 each
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 1:06 pm
3/8" open end wrench 5-Z-195 $20.00
Body bracket connecting holding wrench 5-Z-212 $25.00 each
Carburetor to manifold and generator mounting wrench 5-Z-817 $30.00
Connecting rod cap nut wrench (for removing #4 piston on a 3-dip pan) 5-Z-157 $35.00 each
Crankshaft bearing cap nut wrench 5-Z-153 $25.00
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 1:11 pm
Crankshaft center bearing bolt nut wrench 5-Z-815 $30.00
Driveshaft spool stud nut wrench 5-Z-158 $35.00
Exhaust pack nut wrench 3-Z-524 $35.00
Front and rear spring perch nut speed wrench 3-Z-751 $35.00
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 1:17 pm
Generator third brush wrench 5-Z-249 and 5-Z-806 $20.00 each
Oil pan to engine and transmission bolt speed wrench 5-Z-1835 $35.00
Axle housing nut and bolt wrench 5-Z-152 $25.00 each
Rear axle sleeve puller (heavy duty / unknown manufacture) $40.00
Spindle bushing driver (Unknown manufacturer) $25.00
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 1:19 pm
Valve spring removal wrench 5-Z-319 $25.00
26/27 wire wheel lug nut wrench T-2839 $30.00
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 1:43 pm
Sleeve puller has been sold
One spindle cone wrench sold
Driveshaft stud nut wrench sold.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
One universal joint wrench sold.
Re: FS Z TOOLS
Post by Scott_Conger » Wed Jan 29, 2020 2:05 pm
email sent
NH Full Flow Float Valves
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 2:32 pm
Front spindle bearing cone wrenches are SOLD OUT
One body bracket holding wrench sold.
Another U Joint wrench sold.
Thanks Scott!
tmagill
Last Name: Magill
MTFCA Number: 4444
Re: FS Z TOOLS
Post by tmagill » Wed Jan 29, 2020 4:37 pm
Mark I sent you a PM
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 6:19 pm
26/27 Lug wrench sold.
Spring perch speed wrench sold.
Another Universal joint wrench sold.
Many remaining. Message or call with your needs.
Mark
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Re: FS Z TOOLS
Post by sweet23 » Wed Jan 29, 2020 6:44 pm
E-mail sent
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 8:32 pm
Another universal joint wrench sold to Darryl. Only four remaining.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Wed Jan 29, 2020 10:50 pm
Valve spring removal tool has been sold.
SLinney
Last Name: Linney
* REQUIRED* Type and Year of Model Ts owned: 1919 Model T Speedster
MTFCA Number: 13253
Re: FS Z TOOLS
Post by SLinney » Thu Jan 30, 2020 1:41 am
I will take body bracket connecting holding wrench 5-Z-212 send me an email
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Thu Jan 30, 2020 10:27 am
Pack nut wrench sold to Don. Thanks Don! Thanks MTFCA!
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Thu Jan 30, 2020 10:32 am
Body bracket holding wrench pending to Steve. Thanks Steve!
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Thu Jan 30, 2020 11:37 am
Pan speed wrench sold.
Main bearing nut wrench sold.
Main bearing bolt wrench sold.
Carburetor and generator mounting wrench sold.
Another universal joint wrench sold.
Thanks Scott!
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Thu Jan 30, 2020 6:47 pm
Still have a few remaining. Get them while they last. Contact me with your needs by PM or phone. Mark Chaffin (951) 805-0928
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Fri Jan 31, 2020 1:16 am
One universal joint wrench sold to Scott. Thanks Scott!
I have only one universal joint wrench remaining and then they will be sold out.
Bill Anziani
First Name: Bill
Last Name: Anziani
Re: FS Z TOOLS
Post by Bill Anziani » Fri Jan 31, 2020 6:38 am
I'll take the universal joint wrench
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Fri Jan 31, 2020 2:13 pm
The Universal Joint to Tail Shaft wrenches are now sold out!
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Fri Jan 31, 2020 5:44 pm
I still have the following:
(1) Flywheel to crankshaft bolt wrench $30.00
(5) Connecting rod bolt wrench $25.00
(1) Crankshaft center bearing bolt T wrench $30.00
(1) Driveshaft spool stud nut wrench $35.00
(3) Rear axle bolt and nut wrench $25.00
(1) 3/8 Open end wrench $20.00
(2) Generator 3rd brush adjustment wrench $20.00
(3) 3/8 "L" wrench / transmission cam hut wrench $25.00)
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Sat Feb 01, 2020 9:31 am
All remaining tools listed above are now $20.00 each.
capewake
First Name: David
Last Name: Herring
* REQUIRED* Type and Year of Model Ts owned: 13 Touring, 14 roadster
MTFCA Number: 22001
MTFCI Number: 24521
Re: FS Z TOOLS
Post by capewake » Sat Feb 01, 2020 9:43 am
Hi Mark
I would like to buy one of the universal joint wrenches please.
Emai sent
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Sat Feb 01, 2020 9:01 pm
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS Z TOOLS
Post by Mark Chaffin » Sat Feb 01, 2020 9:41 pm
REDUCED PRICE!!!!!!!!!!!!
(1) Flywheel to crankshaft bolt wrench $20.00
(5) Connecting rod bolt wrench $15.00
(1) Crankshaft center bearing bolt T wrench $20.00
(1) Driveshaft spool stud nut wrench $20.00
(3) Rear axle bolt and nut wrench $20.00
(1) 3/8 Open end wrench $15.00
(2) Generator 3rd brush adjustment wrench $15.00
(3) 3/8 "L" wrench / transmission cam hut wrench $15.00)
Purchase several and save on shipping.
