FS Z TOOLS
Topic author - Posts: 3327
- Last Name: Chaffin
- MTFCA Number: 31705
FS Z TOOLS
I have the following Z tools available for purchase. Quantities available are as depicted in each photo. As well as the price. Shipping for a single item is $8.30 USPO Small Flat Rate Priority envelope. If you purchase two or more, the shipping will be $15.05 USPO Medium Flat Rate Priority. Purchase several items at a time and save on shipping. First come first serve. Get them while supplies last. Payment by PayPal (Preferred) or check. PM me or call Mark Chaffin (951) 805-0928
Connecting rod clamp bolt wrench 3-Z-647 / 5-Z-209 $25.00 each
Flywheel cap screw wrench 3-Z-1179 / 5-Z-210 $30.00 each
1/2" L socket wrench 5-Z-155 $25.00 each
Main bearing bolt wrench 5-Z-156 $25.00 each
Main bearing bolt nut wrench 5-Z-156 $25.00 each
Re: FS Z TOOLS
Universal joint to transmission tail shaft wrench 5-Z-196 $35.00 each
Re: FS Z TOOLS
Body bracket connecting holding wrench 5-Z-212 $25.00 each
Carburetor to manifold and generator mounting wrench 5-Z-817 $30.00
Connecting rod cap nut wrench (for removing #4 piston on a 3-dip pan) 5-Z-157 $35.00 each
Crankshaft bearing cap nut wrench 5-Z-153 $25.00
Re: FS Z TOOLS
Crankshaft center bearing bolt nut wrench 5-Z-815 $30.00
Driveshaft spool stud nut wrench 5-Z-158 $35.00
Exhaust pack nut wrench 3-Z-524 $35.00
Front and rear spring perch nut speed wrench 3-Z-751 $35.00
Re: FS Z TOOLS
Oil pan to engine and transmission bolt speed wrench 5-Z-1835 $35.00
Axle housing nut and bolt wrench 5-Z-152 $25.00 each
Rear axle sleeve puller (heavy duty / unknown manufacture) $40.00
Spindle bushing driver (Unknown manufacturer) $25.00
Re: FS Z TOOLS
26/27 wire wheel lug nut wrench T-2839 $30.00
Re: FS Z TOOLS
Sleeve puller has been sold
One spindle cone wrench sold
Driveshaft stud nut wrench sold.
Re: FS Z TOOLS
One universal joint wrench sold.
Re: FS Z TOOLS
email sent
NH Full Flow Float Valves
Re: FS Z TOOLS
Front spindle bearing cone wrenches are SOLD OUT
One body bracket holding wrench sold.
Another U Joint wrench sold.
Thanks Scott!
Thanks Scott!
- Last Name: Magill
- MTFCA Number: 4444
Re: FS Z TOOLS
Mark I sent you a PM
Re: FS Z TOOLS
26/27 Lug wrench sold.
Spring perch speed wrench sold.
Another Universal joint wrench sold.
Many remaining. Message or call with your needs.
Mark
Mark
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
Re: FS Z TOOLS
E-mail sent
Re: FS Z TOOLS
Another universal joint wrench sold to Darryl. Only four remaining.
Re: FS Z TOOLS
Valve spring removal tool has been sold.
- Last Name: Linney
- * REQUIRED* Type and Year of Model Ts owned: 1919 Model T Speedster
- MTFCA Number: 13253
Re: FS Z TOOLS
I will take body bracket connecting holding wrench 5-Z-212 send me an email
Re: FS Z TOOLS
Pack nut wrench sold to Don. Thanks Don! Thanks MTFCA!
Re: FS Z TOOLS
Body bracket holding wrench pending to Steve. Thanks Steve!
Re: FS Z TOOLS
Pan speed wrench sold.
Main bearing nut wrench sold.
Main bearing bolt wrench sold.
Carburetor and generator mounting wrench sold.
Another universal joint wrench sold.
Thanks Scott!
Thanks Scott!
Re: FS Z TOOLS
Still have a few remaining. Get them while they last. Contact me with your needs by PM or phone. Mark Chaffin (951) 805-0928
Re: FS Z TOOLS
One universal joint wrench sold to Scott. Thanks Scott!
I have only one universal joint wrench remaining and then they will be sold out.
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: FS Z TOOLS
I'll take the universal joint wrench
Re: FS Z TOOLS
The Universal Joint to Tail Shaft wrenches are now sold out!
Re: FS Z TOOLS
I still have the following:
(1) Flywheel to crankshaft bolt wrench $30.00
(5) Connecting rod bolt wrench $25.00
(1) Crankshaft center bearing bolt T wrench $30.00
(1) Driveshaft spool stud nut wrench $35.00
(3) Rear axle bolt and nut wrench $25.00
(1) 3/8 Open end wrench $20.00
(2) Generator 3rd brush adjustment wrench $20.00
(3) 3/8 "L" wrench / transmission cam hut wrench $25.00)
Re: FS Z TOOLS
All remaining tools listed above are now $20.00 each.
- Last Name: Herring
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 14 roadster
- MTFCA Number: 22001
- MTFCI Number: 24521
Re: FS Z TOOLS
Hi Mark
I would like to buy one of the universal joint wrenches please.
Emai sent
Emai sent
Re: FS Z TOOLS
Re: FS Z TOOLS
REDUCED PRICE!!!!!!!!!!!!
(1) Flywheel to crankshaft bolt wrench $20.00
(5) Connecting rod bolt wrench $15.00
(1) Crankshaft center bearing bolt T wrench $20.00
(1) Driveshaft spool stud nut wrench $20.00
(3) Rear axle bolt and nut wrench $20.00
(1) 3/8 Open end wrench $15.00
(2) Generator 3rd brush adjustment wrench $15.00
(3) 3/8 "L" wrench / transmission cam hut wrench $15.00)
Purchase several and save on shipping.
