Wanted 26-27 wire wheel hub puller
Jim Bowery
First Name: Jim
Last Name: Bowery
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 27 Touring, 26 Depot Hack
MTFCA Number: 19036
MTFCI Number: 14288
Post by Jim Bowery » Sun Feb 02, 2020 6:38 am
Wanted 26-27 wire wheel hub puller.
Jim Bowery
Kuhner
First Name: Greg
Last Name: Kuhnash
* REQUIRED* Type and Year of Model Ts owned: 1917, 1921 touring 1927 RPU
MTFCA Number: 28086
MTFCI Number: 21773
Board Member Since: 2006
Re: Wanted 26-27 wire wheel hub puller
Post by Kuhner » Sun Feb 02, 2020 7:07 pm
Jim I sure hope you find one.
I need one also thinking if you get one I could rent it?
I’ve got one stuck on my pick up. Hope to see you at Marietta in a month.
Greg
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun Feb 02, 2020 7:36 pm
A good three jaw has always worked for me. Strike the end after setting tension and they all come loose.
Just trying to Help,
havnfun
First Name: Joe
Last Name: Kowalczyk
MTFCA Number: 49558
Post by havnfun » Sun Feb 02, 2020 7:53 pm
I use a cheap three jaw from Harbor Freight, works GREAT!
Regards,
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sun Feb 02, 2020 9:24 pm
I can't pull a picture over.
I modified a Pittman Arm Puller and it works great. They come in 2 sizes and you need the larger one. You will need to grind off about 1/4 inch of the fingers so it will fit on the hub. Don't think you will find a Model T puller. You would have better luck finding a 2 carat diamond for $10.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Feb 02, 2020 10:14 pm
The Ford puller comes around now & then - there is also an aftermarket Model A hub puller that works. Consider the substantial weight of this puller, it clearly indicates that that axle nut needs to be drawn up TIGHT !
Last Name: Tannehill
MTFCA Number: 49460
Post by JTT3 » Sun Feb 02, 2020 10:22 pm
Steve I knew you’d have one ...maybe 2. Ha
Kuhner
First Name: Greg
Last Name: Kuhnash
MTFCA Number: 28086
MTFCI Number: 21773
Post by Kuhner » Mon Feb 03, 2020 9:07 am
Tried a pitman arm puller, ruined it. Bought another and reinforced it by welding a heavy piece on it, sill opened up. My hub is really stuck.
Greg
MTFCA Number: 49460
Post by JTT3 » Mon Feb 03, 2020 9:58 am
Questions, is it the front or rear hub? Is the wheel off the hub or are you trying to remove the hub from the wheel? If it is the latter I suspect it’s the front hub. What happens over the years dirt & rust get into the space between the wheel & hub and packs it tight. I have had that experience. For that you can lay it front down on blocks and with 2 crow bars opposing each other rock the hub back and forth to wedge it out. As a side note I took a 3200 psi pressure washer and tried to hit between the wheel and hub to remove & soak any of the debris caught in there. I haven’t had an issue on the rear wheels.
