Lot Differential parts at Chickasha
Topic author - Posts: 53
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
I'll have a bunch of rearend parts at Chickasha space FH6. Most are apart and many are measured for wear, so you will know what you are buying. All toll, there are probably 4 or 5rear ends. Will have some axles too (no photo). I also have a number of rear axle housing, but am not planning to bring them unless I get some requests.
- First Name: Jason
- Last Name: McDaniel
- * REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
- MTFCA Number: 50306
Re: Lot Differential parts at Chickasha
Looking for a good right side 1926-27 big brake axle housing and backing plate.
Jason McDaniel
- Last Name: Clements
- MTFCA Number: 49592
I sent you an email about some Hyatt's
- Last Name: Young
Ok, I'll bring a couple axle housings to Chickasha
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
- MTFCA Number: 50661
looking for 39 or 40 ring gear for a 12 or 13 pinion ring gear is cut back so it will accommodate large pinion
- Last Name: Young
All of the R&P are standard 40 x 11 tooth;
- First Name: Jason
Larry, I was able to salvage/repair one of the housings I had on-hand.modernbeat wrote: ↑Tue Mar 10, 2020 3:55 pmLooking for a good right side 1926-27 big brake axle housing and backing plate.
I no longer need a housing, so don't bring them for me. Thanks.
Jason McDaniel
- Last Name: Young
I've decided not to go to the meet, but I still need to clear sell stuff
- Last Name: Bender
- * REQUIRED* Type and Year of Model Ts owned: 1923 auto polo car
How about 26 - 27 radius rods? I would be interested if you have some to bring.
- Last Name: Young
No radius rods
