Got kicked off again.
Topic author - Posts: 979
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
I've gone through this registration/can't log in/etc., etc thing about half a dozen time since the new forum format was activated.
Is anyone else having the problem?
I'll do the whole "new password" thing again and see if it works.
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
- MTFCA Number: 32518
Re: Got kicked off again.
Well, yeah, since you are on, I guess it finally worked. I had a devil of a time getting on yesterday, but whatever the problem was has apparently been fixed.
I have a lot of problems with any "technology", and I think the forum change has been relatively smooth.
Please have patience, there are good men working on it...
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
I have had very few problems using this login pathway
https://www.modeltfordclubofamerica.com/phpBB3/
Use for your bookmark as well
Tony Bowker
La Mesa, California
La Mesa, California
- Last Name: Andreasen
- * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Tony's got the right idea. That's how I finally solved all of my login problems.......just made it a bookmark. Thanks to our mods for that tip!
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 17 roster, 17 touring, 22 coupe, 22 touring, 22 roadster pu, 24 TT cab
- MTFCA Number: 9995
- MTFCI Number: 18113
I was blocked using my Mac with Safari. Now use the Mac with Google Chrome and it works fine. Puzzling!
- First Name: Marv
- Last Name: Konrad
- * REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
- Board Member Since: 2010
-Stan-
Tony identified the link, and George ID'd the 'bookmark' of it. That is the route I've used, and it has worked every time. FYI, you might want to check-mark the "Remember Me" box if you're wanting to go back & forth between 'classifieds and/or discussion'.... FWIW - Not a bad idea either to log out when you're shutting things down. I also use FireFox 'Private Window' to help block a lot of ads.
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
- First Name: Jim
- Last Name: Eubanks
- MTFCA Number: 49847
- MTFCI Number: 8340
Even when I check remember me, I have to log in again every time I start the computer to be able to post. Something is not right because on all the other sites I get on, once you log in and check remember me, you do not have to log in again. Hopefully someone will fix this glitch.
- First Name: Marv
- Last Name: Konrad
-Jim-
Have you cleared your cache of cookies, or deleted the history?
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
I had to log in several times in the past couple days also. Last evening and today has been ok. Back to normal.
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Jim I can login when I first get on. If I want to post something I have to login again. So I write my posting, hit submit, and login comes up. If I post again on another topic I have to login again. Strange.
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
I too have to log in whenever I leave & come back. Tried remember me & bookmarking while signed in. Nothing works. On android
(pad) or Win 10 (lap top). Also I've noticed a very marked increase in junk mail since working to get the new forum useable for me. I'm talking 1 or 2 a day up to (now) 15 or 20 daily. The only changes I've made are adapting to the new Forum. Brought it to Chris' attention.
- First Name: Jeff
- Last Name: Stevenson
- MTFCA Number: 50006
We’re working on it! Still no resolution, but I’m not giving up...Jim Eubanks wrote: ↑Thu Feb 07, 2019 5:21 pmEven when I check remember me, I have to log in again every time I start the computer to be able to post. Something is not right because on all the other sites I get on, once you log in and check remember me, you do not have to log in again. Hopefully someone will fix this glitch.
Jeff
Assistant WebSite Admin
Voltage Regulators, Starter & Generator Repair
www.modeltregulators.com
www.modeltstarters.com
Its still not "remembering me". Hope you get it fixed soon.
Last bumped by Anonymous on Sun Mar 31, 2019 6:31 am.
