Brake Rod Support Brackets
DontKnowMuch
Last Name: Sanford
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Post by DontKnowMuch » Thu Mar 19, 2020 12:49 pm
What is the difference in brake rod support brackets for 1914-15 (3470-71E2 in Lang's catalog) and 1916-27 (3470 & 3471)? Thanks for any help.
* REQUIRED* Type and Year of Model Ts owned: ‘12 open express,'23 cutoff, '27 touring
Re: Brake Rod Support Brackets
Post by DanTreace » Thu Mar 19, 2020 4:06 pm
‘14-‘15 supports have a flat arm that wraps over and under the brake rod.
‘16 and later that arm is stamped and reinforced at the bend just like the curved u-shaped that wraps the radius rod.
2nighthawks
First Name: Harold
Last Name: Schwendeman
Post by 2nighthawks » Fri Mar 20, 2020 4:00 am
Also, to add a bit to Dan's reply, one pair is "show quality", which always costs more, and in the case of each pair, one is not the same as the other,.....one is :left" and one is "right", so as to follow the angled direction of the brake rod.
