Excellent Detailed Videos – Complete Engine & Transmission Rebuild
JWalters
First Name: Jason
Last Name: Walters
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by JWalters » Thu Feb 21, 2019 9:39 am
3:02 Welcome to www.ModelT-Tips.com
11:29 Engine 01 Cleaning the Block
37:17 Engine 02 Babbitt Caps and Block
36:22 Engine 03 Machining Block at Machine Shop
32:21 Engine 04 Line Boring Block
29:48 Engine 05 Finalize Block and Caps
6:12 Engine 06 Painting the Block
18:44 Engine 07 Cam Shaft Installation Part 1
16:25 Engine 08 Cam Shaft Installation Part 2
7:47 Engine 09 Install Valve Lifters
10:36 Engine 10 Install Crankshaft
29:06 Engine 11 Brake Drum and Drive Plate Alignment Part 1
25:09 Engine 12 Brake Drum and Drive Plate Alignment Part 2
21:51 Engine 13 Brake Drum and Drive Plate Alignment Part 3
25:27 Engine 14 Flywheel and Field Coil Part 1
19:33 Engine 15 Flywheel and Field Coil Part 2
20:41 Engine 16 Restore Transmission Drums
20:22 Engine 17 Installing Triple Gears, Field Coil and Flywheel
25:59 Engine 18 Assemble Transmission Part 1
10:27 Engine 19 Assemble Transmission Part 2
20:48 Engine 20 Restoring Hogs Head Part 1
10:04 Engine 21 Restoring Hogs Head Part 2
12:54 Engine 22 4th Main Preparation
10:59 Engine 23 Reline Transmission Bands
13:50 Engine 24 Pistons and Rods Part 1
19:59 Engine 25 Pistons and Rods Part 2
15:21 Engine 26 Piston Installation
12:41 Engine 27 Install Valves
27:00 Engine 28 Restore Pan
21:11 Engine 29 Safety Wire Crankshaft to Flywheel Assembly and Install Front Plate
8:52 Engine 30 Install Pistons
3:38 Engine 31 Install Transmission Bands
3:17 Engine 32 Torque Rods and Main Caps
4:19 Engine 33 Head Options
18:40 Engine 34 Oil Install Pan
18:54 Engine 35 Install Hogs Head, Pedales, Slow Speed Linkage, and Transmission Cover
5:42 Engine 36 Install Head, Valve Covers, and Start Up Process
Jason Walters
Re: Excellent Detailed Videos – Complete Engine & Transmission Rebuild
Post by Steve Jelf » Thu Feb 21, 2019 11:41 pm
Bill, Mike, and Nick have provided a great service for us amateurs who want to learn what we're doing. :)
infotfordnl
First Name: Bert
Last Name: van Amstel
* REQUIRED* Type and Year of Model Ts owned: Runabout pickup 1927
Post by infotfordnl » Sun Mar 03, 2019 4:50 pm
Jason,
this is super, and filming this all is also a lot of work.
It helps me a lot (as amateur)with putting together My T engine and transmission.
Now I have a good view of thee details
Every stap I made, first I look to one of the video's
Very relaxed takes all
Bert
Nice movie of this Model T: https://youtu.be/jD1QJBZasdY
