Odd coil??
My1914T
First Name: Ross
Last Name: Benedict
* REQUIRED* Type and Year of Model Ts owned: 1920 Drs. Coupe
Odd coil??
Post by My1914T » Wed Dec 30, 2020 5:11 pm
Found this in a collection of coils. Can anyone tell me what type it is?
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Odd coil??
Post by R.V.Anderson » Wed Dec 30, 2020 8:39 pm
It's a Heinze. If the bottom contact is towards one end, it's a 1913. If in the center, it's a 1914. I make points for them, so they can be rebuilt like any other early coil.
Re: Odd coil??
Post by Mark Gregush » Wed Dec 30, 2020 8:56 pm
I was going to say Heinze too, but it does not have the little clicker on the adjustment and the plate does not cover the whole top, so might be earlier then 1911.
http://www.mtfca.com/discus/messages/82 ... 1519919768
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Odd coil??
Post by R.V.Anderson » Thu Dec 31, 2020 12:58 pm
It's definitely 1913-14 Heinze, depending on the contact locations I cited. Kingston made very similar coils at the same time but theirs have finger joints only at the top and bottom edges. Heinze units have them all the way up the sides. The ratchet you mention was changed to a very thin T-shaped bronze loop with an embossing that engaged knurling on the underside of the large brass ratchet nut. These thin loops are commonly broken or missing.
jab35
Last Name: Bartsch
Re: Odd coil??
Post by jab35 » Thu Dec 31, 2020 1:09 pm
RV: Has the Coil Documentary article you were working on 2018 been published? I feel this information presented in the format of the recent HCCT book would be of great value and interest. Thanks, jb
