Homemade Manifold oven
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Fri Feb 12, 2021 1:39 pm
How can I make an inexpensive manifold oven?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Last Name: Strange
Re: Homemade Manifold oven
Post by CudaMan » Fri Feb 12, 2021 1:58 pm
If you want to make your own, use CAD (cardboard aided design), some sheet steel, and a 2 x 4 with a slot cut in it for bending sheet metal. :)
http://www.mtfca.com/discus/messages/70 ... 1490635270
http://www.mtfca.com/discus/messages/50 ... 1436971248
http://www.texastparts.com/mm5/merchant ... ry_Code=ex
Post by DanTreace » Fri Feb 12, 2021 2:29 pm
Or just hang a metal box from the exhaust manifold.
A cheap $5 empty steel ammo can is narrow enough to fit and has a hinged snap lid. Remove the rubber gasket from the lid.
Add some metal L shaped straps to hang behind the manifold , with bolts or pop rivets to the backside of the can. You could even dimple the lower end of the ammo can at each manifold stud nut so the ammo can is right against the hot manifold .
Put your prepped meal in a plastic cooking bag , put some water in the bottom of the can, and drive. Check each 20 min and add more water if needed to keep the plastic bag from burning thru. ;) ;)
Post by DanTreace » Fri Feb 12, 2021 2:36 pm
Another’s custom made cooker, note nice lid and how the cooker is stepped to also assist hanging and get full heat contact.
Or ammo can ... :)
Post by TRDxB2 » Fri Feb 12, 2021 2:38 pm
Easy and efficient double wrap https://static1.squarespace.com/static/ ... nifold.pdf
