Anybody Know What This Is
mt15
First Name: gary
Last Name: griffin
Post by mt15 » Tue Jun 01, 2021 5:37 pm
I had this for years. Not even sure where I got it.
I’ve had it at my Chickasha booth several times. A lot of theories
Theories but know positive ID’s
KeithG
First Name: Keith
Last Name: Gumbinger
Re: Anybody Know What This Is
Post by KeithG » Tue Jun 01, 2021 5:47 pm
It's a valve spring compressor.
Keith
mt15
First Name: gary
Last Name: griffin
Post by mt15 » Tue Jun 01, 2021 6:21 pm
I can see that!
A lot of people thought it was a speedometer cable/head/swivel tool.
I give it a try and see how it works.
thanks
Post by RajoRacer » Tue Jun 01, 2021 6:59 pm
Not a valve spring compressor - it's an early Ford speedometer cable end wrench.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Tue Jun 01, 2021 7:11 pm
It is not a speedometer swivel tool. It appears to me to be a valve spring compression tool. Here is a photo of the swivel tool..similiar but not the same. Russ Furstnow
Post by RajoRacer » Tue Jun 01, 2021 8:41 pm
What do I know ? I thought I'd seen that shape before ! A ruler for scale might have helped ?
Post by DanTreace » Tue Jun 01, 2021 9:44 pm
Here's a similar lift, dual ends. The Ford valve end is noted. Found on the web.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Tue Jun 01, 2021 10:39 pm
Steve, Check out second picture with the ruler, it shows the tool to be about 3.5 inches. I don't know what tool is used for.
Post by RajoRacer » Tue Jun 01, 2021 11:56 pm
I really did go in recently for an eye exam !!!
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Wed Jun 02, 2021 6:21 am
I may be way off base here, but I think that may be a tool for FORD watermeters. They use the block letters like that. JMHO Dave
1925 mostly original coupe.
Last Name: House
Post by George House » Wed Jun 02, 2021 2:12 pm
Naw...! Its a shoehorn for Ford employees 👍
