Vaporizer Display
hbarbee
First Name: Hurst
Last Name: Barbee
* REQUIRED* Type and Year of Model Ts owned: 1927 Runabout with Pickup Body
Vaporizer Display
Post by hbarbee » Fri Jul 30, 2021 12:40 pm
After installing the Holley NH conversion kit from Lang's, I restored the Vaporizer and decided to keep it as a display piece. Attached is a picture. Also, if I ever sold the '27 Model T, then the new owner may need it if they wanted to go back to it for some reason.
I was wondering which is more common, the Ford labeled unit like this one or the Holley version?
Hurst
Re: Vaporizer Display
Post by Mark Gregush » Fri Jul 30, 2021 1:29 pm
That one, which is the Holley. The other one was the Kingston, which is way less common.
Post by RajoRacer » Fri Jul 30, 2021 5:25 pm
The Vaporizer had both "Ford" and/or "Holley" name tags - Kingston Regenerator was a different animal !
Last Name: House
Post by George House » Fri Jul 30, 2021 5:40 pm
Steve is right. Holley production couldn’t keep up with Ford T s in 1927 so an agreement was reached allowing Ford to copy the Holley design and affix their own brass ID tag.
Post by Mark Gregush » Fri Jul 30, 2021 6:50 pm
Same with the NH, some have Holley some have Ford tags.
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Post by Jim, Sr. » Fri Jul 30, 2021 10:49 pm
Some of the 1927 Model Ts came with Kingston vaporizers, but they were B-1 Gasifiers, not Regenerators. The Kingston Regenerators were a model made for the aftermarket and were advertised already in 1924 in the Ford Owner and Dealer magazine.
1922 Coupe , 1926 Touring
Post by RajoRacer » Fri Jul 30, 2021 11:19 pm
Appreciate the correction, Jim !
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Sun Aug 01, 2021 12:53 am
Hanging on a wall is what vaporizers do best.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sun Aug 01, 2021 6:26 am
All fine, but was the conversion worth doing? Does it make any difference?
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Thu Aug 05, 2021 12:51 am
Gorgeous!
They do work when good.
