Rear axle
greenacres36
First Name: Brian
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Rear axle
Post by greenacres36 » Sat Aug 14, 2021 4:35 pm
Will an open spool fit on a housing that was made for a closed spool? I see the opposite will not fit. But I have a later spool and I was wondering if it would fit on an earlier housing.
Re: Rear axle
Post by speedytinc » Sat Aug 14, 2021 4:48 pm
Yes. The distance between the 2 faces are the same. You will have to use the later thrust bearings.(open spool)
greenacres36
First Name: Brian
Last Name: Williams
Re: Rear axle
Post by greenacres36 » Sat Aug 14, 2021 5:00 pm
Thank you so much. I was measuring the two and I thought it would work. I am a machinist so I make my own modern bearing spools. I could alter my dimensions a little bit to make it work if I had to.
First Name: craig
Last Name: leach
Re: Rear axle
Post by Craig Leach » Mon Aug 16, 2021 5:13 pm
Brian,
If you have any junk axle housings the tube works good for the spacers.
modern pinion.jpg (21.19 KiB) Viewed 1178 times
