Flywheel ???
Topic author - Posts: 5436
- Last Name: Hatch
Flywheel ???
Anyone ever see a flywheel like this? Has 4 of these, each 90 degrees from each other. Ring gear has same but a counterbore to fit the raised sleeve. Have not tried to see if the “sleeve “ is removable. Does any one know.
Customer brought this to me to rebuild, but looks like he will need a flywheel.
Input???
Thanks Dan
Input???
Thanks Dan
Re: Flywheel ???
YE YES YES. Its a 19. possibly to early 20. One of those really unique 19 features.
Sleeves are removable.
- Last Name: Hatch
Re: Flywheel ???
Was thinking that was the story.
Guess I should save the ring gear for humanity??
NOT! Thanks Dan
NOT! Thanks Dan
Re: Flywheel ???
If the flywheel is in otherwise good shape, and you don't want to use those sleeves, you could just grind them flush and use a standard ring gear.
Re: Flywheel ???
or you could easily modify the new ring gear and let the next guy in 50 years see how '19 cars were built...
Re: Flywheel ???
Well yes, that too. I only mention the other option since he was leaning towards junking the existing flywheel.Scott_Conger wrote: ↑Wed Sep 08, 2021 5:26 pmor you could easily modify the new ring gear and let the next guy in 50 years see how '19 cars were built...
Re: Flywheel ???
No, he was leaning towards junking the ring gear!
- Last Name: Hatch
Re: Flywheel ???
I am going to try and use flywheel.
I was talking about junking the ring gear.
Re: Flywheel ???
I gotta work on that reading comprehension stuff!
