inline water filter on radiator hose
brisketbill
First Name: bill
Last Name: wright
Post by brisketbill » Sat Sep 25, 2021 10:09 pm
does anyone use inline water filters on the radiator hose
Alan Long
First Name: Alan
Last Name: Long
Re: inline water filter on radiator hose
Post by Alan Long » Sat Sep 25, 2021 10:17 pm
I do run one on the 66 Mustang only because it was there when I bought the car. It does catch a fair amount of junk.
Others may have experience using them on T’s and whether they have a negative effect on the Thermo Syphon System.
Alan in Western Australia
Post by Scott_Conger » Sat Sep 25, 2021 10:54 pm
What exactly are you protecting with one?
Post by Steve Jelf » Sun Sep 26, 2021 12:16 am
What?
What?
What?
Post by Allan » Sun Sep 26, 2021 6:26 am
Why? WHY? What the heck for? A model T cooling system needs no impediments.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sun Sep 26, 2021 7:47 am
I would display it on the shelf with my water pump collection….
Post by TXGOAT2 » Sun Sep 26, 2021 10:29 am
If the system has loose debris in it, flush it. Unless the filter is enormous, it will plug quickly if there is anything loose in the system.
Post by TRDxB2 » Sun Sep 26, 2021 12:12 pm
Adding a water pump is usually an attempt to solve a over heating problem. Adding a water filter may be an attempt to solve or prevent a similar issue. Like most questions: Why did you ask - curiosity or results of a flush?
Post by speedytinc » Sun Sep 26, 2021 12:32 pm
If you are already running a water pump, maybe it will catch crap until it plugs up. If your system is still thermosyphon, NO. Any impedance will mess with your cooling. This is as good an idea as putting on inline fuel filter. "Why doesnt my T run up hill?"
Post by Jerry VanOoteghem » Sun Sep 26, 2021 9:02 pm
Let's go easy on the OP, he's a first time forum user.
As you can see, a filter is not really a good idea for a T cooling system. :)
Post by speedytinc » Sun Sep 26, 2021 9:55 pm
I do hope the OP understands no malice or taunting is intended. We are trying to help educate the gentleman.
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Mon Sep 27, 2021 8:33 am
Gee Wizz, that’s a very fine filter and nothing like the Cone shaped, Plastic one in my Mustang Top Radiator Hose which would
only catch real big stuff, so basically useless. No way would I fit any filter in any of my Model T’s
