1925 Ford Timer Assembly
Wascator
Topic author - Posts: 7
- First Name: Randy
- Last Name: Roberson
- * REQUIRED* Type and Year of Model Ts owned: 1925 Fordor, 1926 Coupe
I bought a reproduction Ford timer, new roller, roller pin, brass shield, and felt. The brass shield and felt were missing from my car, so I am unsure about how they go. I pushed the felt seal snugly in place (I think) but what holds the brass shield? Is tgere a washer between it and the roller!
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: 1925 Ford Timer Assembly
If I remember correctly, the timer holds the shield in place, so when the timer is off the shield will be loose.
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
On roller timers that require lubing a tiny bit every 200 miles or so I have never found it necessary to use the felt or brass shield.
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
The last few engines I put together I did with the modern cam seal and didn’t use the felt or shield. All is good. Clean the timer housing when I think about it and go on with life.
Brad
Brad
Russ T Fender
- First Name: Val
- Last Name: Soupios
If you use the brass shield make sure it is big enough to span the timer case. Some repro shields are too small and are not held in place by the timer adequately.
