Generator Gear Puller
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post by CatGuy » Fri Jul 15, 2022 9:28 am
What is the proper puller to use to remove the gear on the generator? This is on my '26.
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Re: Generator Gear Puller
Post by FATMAN » Fri Jul 15, 2022 9:42 am
This is the correct tool that I use, Bob
CatGuy
Last Name: Hunt
Post by CatGuy » Fri Jul 15, 2022 10:21 am
Also, do rebuilt generators have a better cutout system? I keep reading about overcharging issues.
Last Name: Tannehill
Post by JTT3 » Fri Jul 15, 2022 10:31 am
Scott the generator is a “system” and the cutout is a “system”, the model T generator does not have a integral cutout built into it. It’s an add on in the form of a mechanical or electrical encapsulated device.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Fri Jul 15, 2022 10:46 am
Sorry...But the Model T, for as simple as it is, it is not a low maintenance vehicle. When you get your generator operating again, follow the instructions for the setting of current, if you you use a mechanical cut out, adjust the system as recommended in the literature.
Check the car every time you start it up - oil, charging, coolant, tyres, etc.
And recheck the vehicle every 500 miles.
The as designed systems work, remember too that in modern vehicles there are micro chips monitoring the systems...with a Model T, you are the engine/vehicle management system.
CatGuy
Last Name: Hunt
Post by CatGuy » Fri Jul 15, 2022 11:12 am
I've often been intrigued by the comparison. Old cars require more work, more frequently, but it's easier, sometimes cheaper and you can do it at home by yourself. New cars require less work, less frequently, but it's harder, more expensive and you can't usually do it at home by yourself. (At least with me)
Post by Norman Kling » Fri Jul 15, 2022 12:20 pm
Unless you have an aftermarket voltage regulator, the generator is set to charge by adjusting the third brush at the top. loosen the nut and slide toward the engine to increase the charge and move away from the block to lessen the charge. If you drive often, long distances during the daylight hours you can set it for around 4 amps charge. If you drive mostly with the lights on, adjust it to just read about zero with the lights on. If you drive infrequently for short distances, you can set it for 5-10 amps. If you think you might be overcharging turn the lights on.
Anyway, you get the point. How you adjust it depends on how easy it starts with the starter and how often you drive and under what conditions you drive.
Post by JTT3 » Fri Jul 15, 2022 12:58 pm
I hesitate to ask, have you solved the charging problems you were having in the thread you started in June?? Did you purchase another generator for your car?
CatGuy
Last Name: Hunt
Post by CatGuy » Fri Jul 15, 2022 1:09 pm
No. For a bit there I decided to sell it, but realizing that I'd have to take a big loss on the car I pulled the ad. It was on Facebook. I would still sell it, though, even though I do like the car. I have tested the generator and magneto with common tools that I have at hand just as the Ford mechanics would have done back then and found that both are dead. The magneto will have to wait. The generator seemed simple enough and it probably is once I get the gear off. Birdhaven in Colfax is less than and hour from me and open tomorrow. We'll see. I did reverse the wires on the back of the ammeter and it shows a discharge when it's appropriate for it to do so. It appears to be backwards of what it should be, though, but it works.
Last Name: Hatch
Post by Dan Hatch » Fri Jul 15, 2022 1:39 pm
Mag is easier fix that generator. Just takes a couple 12 volt batteries and a compass. If the coil is good and most are.
Generator will most likely need an armature.
Post by TXGOAT2 » Fri Jul 15, 2022 2:52 pm
Be sure to pull the pin out of the gear before pulling it.
Post by speedytinc » Fri Jul 15, 2022 4:24 pm
If the generator is allowed to over produce, (cutout failure typically) It will sling solder from the commutator. There is obvious solder spit under the end cap. The commutator can be re-soldered. Typically the solder connection breaks before total destruction & the armature is savable.
The most common failure is from the 3rd brush insulator being over tightened, & broke, allowing the brush holder to contact ground.
Also possible & the easiest to fix is gummy, oily brushes or brushes worn down to far. Spray some brake cleaner & give it a good visual whall still on the motor.
CatGuy
Last Name: Hunt
Post by CatGuy » Fri Jul 15, 2022 10:05 pm
Would most any puller work?
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Fri Jul 15, 2022 10:18 pm
Only if they have the clearance for the legs to fit between the housing and the gear.
