Fan hub bushings
Rich P. Bingham
Topic author - Posts: 1814
- First Name: Rich
- Last Name: Bingham
Fan hub bushings
I have some notions on changing out the worn bushings, but I'll bet our members can offer some valuable tips ! 1916-20 (?) cast iron hub. Thanks, fellows !
- Attachments
- 3768F7D0-87AC-496E-AEF0-E5210204A2ED.jpeg (29.2 KiB) Viewed 1037 times
Get a horse !
Rich P. Bingham
- First Name: Rich
Re: Fan hub bushings
And the front :
- Attachments
- 91ABDE77-6B6E-4672-8DE9-F0479F144983.jpeg (31.05 KiB) Viewed 1035 times
Get a horse !
A pipe tap threaded in either end then tap out with a drift.
Some I have seen have been soft soldered in place, presumably because the bush was not a good fit. A little heat may be in order while driving on the tap.
- Last Name: House
They’re very easily driven out with a 3/8” brass punch since they’re dissimilar metals with no rust. I keep the old bushings and cut them about 1/8” beyond the flange. Needle bearings are controversial with this crowd. I use them with no problem on all my Ts then reinstall the cut off bushings....Original will disagree
