Need help identifying front fender
frank.koonce
Last Name: Koonce
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Roadster, 1927 fordor
Post by frank.koonce » Fri Feb 24, 2023 7:14 pm
[image][/image][image][/image]
Hello, I have a 1915 runabout that needs a right front (passenger side) fender. I have what I think is a correct left fender, with three rivets, a bill, and a flat top. A friend brought me the red fender, which also has three rivets, thinking that it was what I needed. However, as you can see in two of the attached pictures, it is wider than mine and has a bill that is shaped differently. I am thinking that the red fender may be off of a speedster or a torpedo. I would be very grateful if anyone could solve the mystery.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Need help identifying front fender
Post by ThreePedalTapDancer » Fri Feb 24, 2023 7:25 pm
I believe the wider fender is a wide track fender for a wide track T seen here.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Feb 24, 2023 7:27 pm
Ed, I agree with you those wide track Fords were sold mainly in the southern states
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Post by pre15dale » Sat Feb 25, 2023 9:02 am
Definitely wide track. I have a pair of them. I advertised them a couple years ago, there was no lnterest
Last Name: House
Post by George House » Sat Feb 25, 2023 11:07 am
Yep 😜 You guys are good ! Also known as southern tread.
Post by speedytinc » Sat Feb 25, 2023 3:00 pm
Wide track. I might be interested in it. I have an early 15 widetrack. The fender was severely damaged @ some point in its life & has the scars on the underside to prove it. Interestingly it has 4 rivets holding the mounting bracket.
frank.koonce
Last Name: Koonce
Post by frank.koonce » Mon Feb 27, 2023 7:03 pm
Thanks to everyone for their replies. Problem solved!
Frank
