re-babbitted connecting rod ( singles)
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Tue Jul 18, 2023 10:27 am
I have several re-babbitted connecting rods that are separate from sets ... this can be very handy for instances where you are on tour and loose a connecting rod ... a spare rod can save the event ! I have 2 Standard diameter rods ... 1 -.010" diameter rod ... 2 -.020" diameter rods ,and 1 -.030" diameter rod ...rods are re-babbitted , X grooved , drilled for dippers and checked for alignment ...price is $75 each WITHOUT CORE includes postage in lower 48 states ... i can add actual postage outside this area ...Gene French 970-581-2808
conn rod 1.jpg (37.99 KiB) Viewed 1167 times
Gene_French
First Name: Gene
Last Name: French
Re: re-babbitted connecting rod ( singles)
Post by Gene_French » Sun Oct 01, 2023 11:31 am
to the top again ...thanks MTFCA
Post by Allan » Mon Oct 02, 2023 7:42 am
Gene, might you have an orphan A model rod at .010" under?
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Mon Oct 02, 2023 3:52 pm
Allan:
i will check my used parts ... the single rods i have listed are all Model T ... i do have buckets full of A rods , some in very usable condition ... will let you know if i find anything that is suitable for use ...Gene French
Post by Allan » Mon Oct 02, 2023 6:11 pm
Thanks for the response Gene. My son is looking for a rod for the guy who is painting his 1970 Ford falcon ute. A good used on at .010" under would do.
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Wed Oct 04, 2023 8:08 pm
Allan:
sent email ...
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Oct 07, 2023 10:45 am
Allan:
sent an email to the address you sent me ...have a servicable rod here ... pay postage to Au. and it's yours ...Gene French
