Double Hassler Shocks
GOLDBARBILL
First Name: William
Last Name: Conner
* REQUIRED* Type and Year of Model Ts owned: 14 Speedster
Post by GOLDBARBILL » Wed Nov 01, 2023 1:59 pm
When installing double soring hassler shocks, is it necessary to have/use two spring compressors? Bill Coupeville, WA
Re: Double Hassler Shocks
Post by RajoRacer » Wed Nov 01, 2023 3:15 pm
I did when I installed mine - think about it.
Post by TRDxB2 » Wed Nov 01, 2023 3:19 pm
I would say positively YES. There are enough warnings regarding working on a single spring with a compressor. Also just one would not give even compression on the other.
Afrazer
First Name: David
Last Name: Frazer
* REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Post by Afrazer » Wed Nov 01, 2023 4:51 pm
Most definitely yes. Just took a set off had to move one side down a little then the other spring and so on till I could take the brackets off the springs
1925 closed cab TT
1926 two door sedan
