Motel t crank 26/27
Psainslie
First Name: Patrick
Last Name: Ainslie
Motel t crank 26/27
Post by Psainslie » Sun Jun 23, 2019 12:11 pm
WTB good used 26/27 crank that is not more 10 thousand under and has been magnifluxed and would be satisfactory for use in an engine overhaul. Pat
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Motel t crank 26/27
Post by Adam » Sun Jun 23, 2019 12:22 pm
FYI. A ‘26/‘27 crank with .003/.004 wear might clean up at -.010”. If it has .008 or more wear, it is likely to go -.020”. Most all of the ‘26/‘27’s wear off center on the rear main and grind more than double the wear measurement. Just something to be aware of in your search.
Psainslie
First Name: Patrick
Last Name: Ainslie
Post by Psainslie » Sun Jun 23, 2019 1:08 pm
That is one of the reasons to start with a crank that isn’t already .020 or more to start with Thanks
