Re-babbitted T mainbearing caps
Gene_French
Topic author - Posts: 1091
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
set of model T caps bored to -.010 undersize ... these were removed from a lightly used engine when a Scat crankshaft was installed ... thrust on rear cap measures 3.125" bore is 1.240" ... could be easily refit to a worn standard crankshaft by using Timesaver lapping compound or fit to a minus .010 crankshaft ... price is $90.00 + $19.15 postage in lower 48 states , actual postage outside this area or INTERNATIONAL ... contact me thru MTFCA site ...Gene French
Gene_French
- First Name: Gene
- Last Name: French
Re: Re-babbitted T mainbearing caps
to the top ...thanks MTFCA
