Part name needed
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Part name needed
Post by tom_strickling » Sat Nov 29, 2025 10:03 am
What is the semi-rounded metal strip that goes around the back of a Fordor to cover the sheet metal seam called?
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
tom_strickling
Re: Part name needed
Post by tom_strickling » Sat Nov 29, 2025 10:17 am
AND Does anyone have one to sell ? The car is missing about 1/3 of this piece on the passenger side.
Last Name: House
Post by George House » Sat Nov 29, 2025 12:27 pm
Tom,
If I take “around” to mean on the horizontal, we call it the ‘belt line’.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sat Nov 29, 2025 1:31 pm
Locally we call it a 'body moulding' or 'D-Moulding" and yes, a close profile is available .... here in New Zealand.....
Probably other aluminum extruders make a similar one, possibly for coach building or boat building industries maybe.
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Sat Nov 29, 2025 1:41 pm
The 1925 Price List of Body Parts lists it as Moulding, Rear Belt, part number 17163X.
tom_strickling
Post by tom_strickling » Sat Nov 29, 2025 2:20 pm
Thanks all. Now I need one or the passenger side 1/3 of one.
Post by John kuehn » Sat Nov 29, 2025 4:06 pm
You can fabricate one out of half rounded moulding that can be bought in different lengths and widths. You can buy it from industrial supply houses. It’s used for trimming out shelving, kitchen areas in restaurants, and other similar uses. I bought some years ago to finish out the seam trimming on the back of my 1919 T runabout.
Most of the trim pieces if not all is not reproduced. These prices you have to make.
tom_strickling
Post by tom_strickling » Sat Nov 29, 2025 5:10 pm
It seems like it is less than half and metal
Post by John kuehn » Sat Nov 29, 2025 6:50 pm
The moulding seems to be made from some type of aluminum or pot metal. I have a 24 T Coupe and did have a 25 Four door sedan which I sold several years ago. Both of them had the moulding and was made of the same aluminum type material. It was nailed on with a type of finishing nail and then counter sunk. The small hole was filled in with putty and then sanded down before the bodies were painted I’m assuming.
modeltspaz
Last Name: Spaziano
Post by modeltspaz » Sat Nov 29, 2025 8:32 pm
I believe that a similar question was posted here on the Forum recently, and was answered by Mr. Pete Eastwood.
If I recall correctly, his answer stated that the body molding is available from Restoration Supply Co. They have an unusual website address. If you search Restoration Supply it will direct you to a vintage home hardware supply company. Make sure you look for antique auto supply parts.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat Nov 29, 2025 8:45 pm
Restoration Supply in California sells a extruded aluminum molding, part number MOU 035. It is a T shaped molding, sold in 8 ft. lengths. Current price is $60.00 if I'm not mistaken.
Post by TRDxB2 » Sat Nov 29, 2025 10:27 pm
Does this help?
