FS Model A Insert Connecting Rods / Pistons / Rings
SMHnat
First Name: Seamus
Last Name: Hnat
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford T Touring
Post by SMHnat » Mon Feb 23, 2026 12:55 pm
Set of Four matched set forged model A rods $350
Standard rod bearing set $150
New diamond pistons 0.060 $125
Piston Ring set $45
Buy it all for $650 + shipping if needed, located 20 minutes SW of Port Huron, Michigan
Seamus Hnat
Antique & Collector Car Specialist
Ford Ts As & V8 Cars
Specializing in Precision Tuning & Carburetion & Ignition Systems
Full Service Shop for your Antique Car needs
Richmond, MI 48063
(586) 909 - 2969
smh.restoration@gmail.com
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: FS Model A Insert Connecting Rods / Pistons / Rings
Post by Kevin Pharis » Mon Feb 23, 2026 1:56 pm
Nice setup Seamus! Hard to tell from the pic, are those high wrist pin pistons for using full length A rod and A crank in T block?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Feb 23, 2026 4:49 pm
Seamus- PM and email sent on the pistons and rings.
