Installing Manifolds
bill goodheart
First Name: William
Last Name: Goodheart
Post by bill goodheart » Sat Jul 20, 2019 1:18 pm
Is the manifold installation tool sold by Langs (#3066MTG) for $29.95 worth having? Does it make a difficult job easier? Can the job be done without the tool?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Installing Manifolds
Post by Humblej » Sat Jul 20, 2019 1:30 pm
The job can be done easily without a tool if you have a helper, or with some effort by yourself. A manifold clamp with one arm cut off makes a good tool.
Post by Steve Jelf » Sat Jul 20, 2019 1:55 pm
I hate the idea of cutting up original parts, so I made these.
Post by Mark Gregush » Sat Jul 20, 2019 2:12 pm
I just turn the two outer clamps sideways and install the exhaust manifold first then the intake and two inner clamps, no cutting involved. Does the tool work, I am sure it does, is it needed, not really. There are work around's.
Post by RajoRacer » Sat Jul 20, 2019 3:07 pm
I have coffee cans of both style clamps so cutting a couple off didn't hurt my feelings none but I do reverse of Mark's installation procedure - I install intake first to verify ring & gland seating then install exhaust as you can also verify seating looking down across the manifold - you can't see the intake if you mount the exhaust first. 8-)
AdminJeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by AdminJeff » Sun Jul 21, 2019 1:55 am
I got a couple of these from Erik B when we did my tranny. Boy did they help while I redid my Winfield linkage last week. Intake was on an off a dozen times until I got it right. In hindsight, I should have removed the exhaust manifold and done it last as you suggested though. Would have saved some grief for sure! Next time!
Jeff
Assistant WebSite Admin
1921 Model T Touring, 1930 Model A Roadster
Voltage Regulators, Starter & Generator Repair & Parts manufacturing
www.modeltregulators.com
www.modeltstarters.com
bill goodheart
First Name: William
Post by bill goodheart » Mon Jul 22, 2019 10:09 pm
Thanks to everyone for the helpful suggestions. I got the answer I was hoping to get, I don't need to buy the tool to do the job. I can hold on to my $30.00 for something I really need. I hope to be installing both manifolds in a couple of weeks That is if I can finds enough time between Drs. appointments. I hope to get the engine back in my 1919 touring this summer.
