Mirrors
John iaccino
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Re: Mirrors
Don Lang has a hinge pin mirror for sedans.
Re: Mirrors
Dale, the hinge pin mirrors stocked by the vendors will do the job, but you need to be comfortable with Phillips head screws and stainless steel heads. I was able to find some 60's mirror heads to replace the stainless ones which were on my car. They look much more at home.
D.Trotter
Topic author - Posts: 9
- First Name: Dale
- Last Name: Trotter
Re: Mirrors
Thanks to you both, I'll check them out. I have also seen some that clamp over the door edge but don't know much about them.
Re: Mirrors
The "clamp over the door edge" type are generally a later style. Mostly '40s and '50s. I have seen a couple real early ones, but not many.
D.Trotter
- First Name: Dale
Re: Mirrors
Gotcha, thanks.
