1924 Model TT Ford One Ton Truck
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Tue Aug 13, 2019 9:39 pm
1924 Model TT Ford One Ton Truck - $15,000 OBO
I’m selling this truck for a good friend, Barney Deden.
This Ford truck was originally purchased by T.A. Moneypenny of Crete, Nebraska from a Ford dealer in Beatrice, Nebraska.  The dealer ordered the truck without a starter or generator to save money for the buyer.  He also ordered only the chassis, drive train, fenders and hood.  He then installed an “after market” cab and box which also saved on the cost of the truck.  These changes not only saved money it also made the truck much lighter than the factory model which had a very heavy steel cab and bed.  This lighter truck allowed the farmer to have more hauling capacity for the little 20 horse engine.  Extensive on line research shows a cab and box very similar to this one was manufactured by the Patriot Manufacturing Company of Havelock, Nebraska, a suburb of Lincoln.  Patriot was a wagon manufacturer which expanded into truck boxes after the introduction of small trucks by car manufacturers in the late 1910’s.  The truck boxes are very similar to the earlier wagon boxes.
On the death of Moneypenny the truck was passed to his step-son, Joseph L. Vance and spouse, Hazel P. Vance of Pleasant Dale, Nebraska.  Sometime in 1980 Joe Vance sold the truck to Jerry Martin of Omaha, Nebraska.  Jerry never re-titled the truck.  He drove it sparingly for a few years and it then sat untouched in his garage for about 30 years.  Barney Deden purchased it from Jerry October 11, 2011.  Barney immediately set about a complete disassembly, cleaning and restoration from the frame up.  A search for a replacement right rear axle found a complete rear end in great shape which also had a working Ruxtell axle.  While re-building the rear end a “high speed” ring and pinion was installed to make the truck easier to drive in todays traffic.  The new gears provide a ratio of 5.17:1 while the original gears were 7.25:1.  This resulted to about a 10 mph increase over the factory rear end, with a road speed of 27 mph +.
Some comments on the restoration:
The engine and transmission were disassembled without removing the pistons.  They and the cylinders showed no unusual wear.  The valves were “hand ground” and the valve springs were replaced.  New bushings were installed in the transmission and the transmission bands were replaced.  The magnets were charged.  On reassembly the engine starts easily on a small 6 volt battery and runs very smoothly on the mag.  The gas tank was cleaned by a radiator shop and the inside was coated with a preservative.  New spindle bushings and king pins were installed.
The wood on the back and top of the cab and some other small pieces was weathered beyond restoration.  It was replaced with poplar wood, a light wood to save weight.  The back window was increased in size to make it twice as wide and make it easier to see behind while driving.  A new seat and back cushion were installed.  All glass was replaced with new safety glass.  None of the wood in the box was salvaged.  The support members were reproduced with the weight-saving poplar wood.  The box floor and sides were copied from the originals but made of red maple with 3 coats of polyurethane.  The hardware on both the cab and the box is the original hardware, cleaned and repainted.  The original black wood spokes were sanded and finished with polyurethane.  New tires were installed.
The original truck box had two more tiers of side and front boards.  They were saved for patterns, it wanted.
Please contact George Schmidt for additional photos or if you have any questions.
Unprr@cox.net
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Re: 1924 Model TT Ford One Ton Truck
Post by Unprr » Wed Aug 14, 2019 3:47 pm
X
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sat Aug 17, 2019 6:30 pm
X
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Tue Aug 20, 2019 8:49 pm
More photos attached.
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Tue Aug 20, 2019 9:06 pm
I’m adding additional photos of the 1924 Model TT Truck being offered, for sale. Along with the purchase, is a photo book of the complete restoration. This book has over a hundred photos, along with 40 pages of invoices, covering parts put into this project.
Additional photos to follow. Note, I’m having trouble placing the photos in time order, sorry.
Contact me at unprr@cox.net
George Schmidt
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Tue Aug 20, 2019 9:09 pm
Additional photos of the 1924 ModelTT truck restoration, taken directly out of the build book, which comes along with your purchase.
George Schmidt
Unprr@cox.net
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Thu Aug 22, 2019 1:40 pm
Make an offer before this beautiful truck is gone.
George Schmidt
Unprr@cox.net
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sat Aug 24, 2019 10:45 am
X
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sun Aug 25, 2019 11:00 am
The price has been lowered to $14,000 OBO.
Note photo of the build book on this truck. It contains photos of the complete rebuild, along with about 40 pages of invoices. You will never find more detail on any rebuild.
All offers considered.
Thanks,
George Schmidt
Unprr@cox.ne
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sun Sep 01, 2019 3:49 pm
I may list the truck on E -Bay. Please help me save the commission, let’s make a deal,Today.
George
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Fri Sep 20, 2019 9:13 pm
TT Ford
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Fri Sep 27, 2019 9:48 am
Larry, I have tried e mailing you , with the address given, with no reply. I had a few other inquiries. And replies and may have missed yours.
George
George,
I sent you an email when you first listed this truck for sale and didn't
get an answer. Now that I know it is still for sale with little to no
interest,
email me if you want to try and work a deal.
Thanks in advance
Larry LaPatka
Parrottsville, Tennessee.
email: ltlapatka@gmail.com
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Wed Oct 16, 2019 3:23 pm
Please note:
Price has been dropped to $12,500.
Let’s make a deal.
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Thu Oct 17, 2019 9:10 am
George,
I have sent previous emails and I'll try again.
I have a 1914/15 Ray Wells bodied C Cab Model T truck that is 85% finished.
All it needs is the sheet metal repainted
select the lights, and touch up the body sides. I have $14,250 into it but
I would like to know if you have interest in
trading with your TT. I am sure we could work out something for the
difference.....Freight? Let me know.
Regards
Larry LaPatka
Larry,
I have tried to contact you in return. The seller has given me the new reduced price of
$12,500. He doesn’t want to trade but reduce his collection. If you would like to make a cash offer, he is open to deal.
Thanks George
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Thu Oct 17, 2019 1:46 pm
Larry, since your having trouble contacting me via my e-mail. Please respond on the Model T Forum. That’s the page you saw the truck, for sale on.
George Schmidt
Sent from my iPad
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sun Jan 19, 2020 8:20 pm
1924 Model TT
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sun Jan 19, 2020 8:39 pm
1924 Model TT , now priced at $12,500.
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sun Feb 16, 2020 7:10 pm
1924 Model TT, reposted.
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Mon Feb 17, 2020 12:16 am
The seller needs the room and has lowered the price on this beautiful truck to
$11,750.00
Don’t let it get away.
George Schmidt
Unprr@cox.net
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Wed Feb 19, 2020 1:41 pm
Larry, I sent you my phone number. Give me a call.
George Schmidt
George,
Email me your phone number so we can talk about the TT. I have sold my 15 C Cab and I am thinking
about making you an offer on purchasing the TT.
Regards
Larry LaPatka
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Fri Mar 27, 2020 7:04 pm
Xxx to the top
Ewalny
First Name: Eido
Last Name: Walny
Post by Ewalny » Sat Mar 28, 2020 9:46 pm
Is this truck in Wisconsin?
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sun Mar 29, 2020 1:16 am
It is in Elkhorn, Nebraska
Last Name: Seth
Post by perry kete » Sun Mar 29, 2020 1:33 pm
If the house didn't need a new roof I'd be all over this like flies on ... That truck is beautiful!
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sun Mar 29, 2020 11:05 pm
Ewainy and Dhort, the truck is located in the Omaha area.
Perry, thanks for such nice words.
George Schmidt
Unprr@cox.net
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sun Apr 19, 2020 10:27 am
George Schmidt
Unprr@cox.net
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Sat May 02, 2020 11:09 pm
George Schmidt
Unprr@cox.net
Pric3 lowered to $11,750.00
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Thu Jul 09, 2020 5:08 pm
Priced at $11,750.00
E mail George at
Unprr@cox.net
Crazy'boutTs
First Name: Fred
Last Name: Bryant
Post by Crazy'boutTs » Wed Jul 15, 2020 12:28 pm
do you still have truck for sale. if so can you call me 704 692 5282 my name is FRED THANKS.
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Wed Jul 15, 2020 8:23 pm
Fred, I returned your call and placed my phone number, on your phone mail.
George Schmidt
Crazy'boutTs
First Name: Fred
Last Name: Bryant
Post by Crazy'boutTs » Wed Jul 15, 2020 9:11 pm
thank you sir. i will call you tomorrow 10 to 12 am if its ok. THANKS ALOT.
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Thu Jul 16, 2020 6:15 pm
Fred, thanks for the call , sorry I was out fishing, LOL.
If you send me your e mail, I will forward more photos of the truck and it’s restoration.
George Schmidt
Unprr
Last Name: Schmidt
MTFCA Number: 49710
Post by Unprr » Fri Jul 31, 2020 11:49 pm
Mike, the TT truck is still for sale.
George Schmidt
Unprr@cox.net
